debby1499
#1 Posted : Saturday, July 25, 2009 2:08:22 PM(UTC)
debby1499
water leaks from the inside front of the refrig by the light when the ice maker is turned on. :mad: help!
#2 Posted : Sunday, July 26, 2009 3:42:32 AM(UTC)
Is the icemaker overflowing with water?
debby1499
#3 Posted : Sunday, July 26, 2009 5:58:22 AM(UTC)
debby1499
it does not appear to be overflowing with water, it is making ice. we had not been using the ice maker for awhile which was a problem with the water line becoming clogged with calcium. we cleaned and cleared the water line and also installed a filter for the water line. when we started the icemaker up again, by the next day it started leaking water into the refrig as described in my previous message. any ideas?
#4 Posted : Sunday, July 26, 2009 6:16:57 AM(UTC)
Remove the back panel of the fridg. locate the water solenoid, and stick 115 volts to the water solenoid valve, then see where the water is going in the freezer, you may have a bad water line or a partially iced up line spraying water in the freezer.
GE Refrigerator “dead” (Refrigerator & Freezer Repair)
by Guest 12/3/2023 8:03:32 AM(UTC)
GE refrigerator inside light not working (Refrigerator & Freezer Repair)
by Guest 11/18/2023 10:01:46 AM(UTC)
GE Refrigerator model# TFF24RBC (Refrigerator & Freezer Repair)
by Kenny67 11/3/2023 8:29:39 PM(UTC)
Dim interior LEDs in GE Refrigerator - update (Refrigerator & Freezer Repair)
by Craigma 11/3/2023 12:37:37 PM(UTC)
GE refrigerator/freezer, freezer compartment gets above freezing, ice cubes melt together (Refrigerator & Freezer Repair)
by CT Redmond 7/2/2023 1:59:53 PM(UTC)
GE refrigerator icemaker freezing up (Refrigerator & Freezer Repair)
by Guest 7/1/2023 6:40:00 AM(UTC)
New GE refrigerator not cooling to set temp of 35 (Refrigerator & Freezer Repair)
by VarMan 6/16/2023 5:05:53 PM(UTC)
GE Refrigerator parts (Refrigerator & Freezer Repair)
by Guest 6/5/2023 7:31:51 AM(UTC)
GE Refrigerator diagnostic mode error codes (Refrigerator & Freezer Repair)
by Guest 1/22/2023 10:11:53 AM(UTC)
GE Refrigerator Model PSS26LSRF SS (Refrigerator & Freezer Repair)
by Phoenician 8/14/2022 10:03:28 AM(UTC)
GE Refrigerator Model GSS23WSTASS (Refrigerator & Freezer Repair)
by lkrier0612 7/18/2022 6:18:04 PM(UTC)
GE Refrigerator PWE23kskkss (Refrigerator & Freezer Repair)
by bubba1531 4/14/2022 6:47:57 AM(UTC)
GE Monogram Fridge Refrigerator All lights stopped working...ZISP480DXBSS (Refrigerator & Freezer Repair)
by sidhup77 1/28/2022 4:55:12 PM(UTC)
GE Refrigerator #GSHS5KGXBCSS No water and loud noise after filter replacement (Refrigerator & Freezer Repair)
by Guest 8/26/2021 6:48:33 PM(UTC)
Samsung ice maker in GE Refrig - (Refrigerator & Freezer Repair)
by ken.musick72@gmail.com 8/11/2021 1:23:13 PM(UTC)
