Discuss
Side by Side refrigerator/freezer side not cool
 in
Refrigerator & Freezer Repair
HELP! Amana ARS2665AB Freezer part of side by side does not get cold enough anymore. Unit stopped making ice cubes
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Side by Side refrigerator/freezer side not cool
  #1 (permalink)
Old 07-25-2009, 10:41 AM
Junior Member
baq66 is on a distinguished road
Default Side by Side refrigerator/freezer side not cool
Model Number: ARS2665AB   Brand: Amana   Age: 5 - 10 years
HELP! Amana ARS2665AB Freezer part of side by side does not get cold enough anymore. Unit stopped making ice cubes a few days ago. Ice cream turns to mush after a few hours. Other items, like frozen meats, seem to stay frozen just fine. Not sure if unit is cooling, only not correctly, or if items frozen are frozen simply becuase of the insulation in the unit itself.
I done following:
-vacuumed dust out of front panel (under doors), in condenser area, and inside of fan housing.
-gradually turned up the temperature over a couple of days. Freezer stays around 15 - 20 degrees and fridge around 40
Condenser fan and freezer coil fan is running. The coils in the freezer itself if clear without ice or frost and it cold to the touch.
What's next? Should I call a repair man or should I just back a new one. The unit is about 9 years old.
Thanks for any help.
Ads By Google
Related Models
Amana ARS2665AB Ref - SXS/I&W
Amana ARS2665AC Ref - SXS/I&W
Amana ARS2665AW Ref - SXS/I&W
Amana ARS2666AB Ref - SXS/I&W
Amana ARS2666AC Ref - SXS/I&W
Amana ARS2666AW Ref - SXS/I&W
Amana ARS2667AB Ref - SXS/I&W
Amana ARS2667AC Ref - SXS/I&W
Amana ARS2667AS Ref - SXS/I&W
Amana ARS2667AW Ref - SXS/I&W
Amana ARS2667BB Ref - SXS/I&W
Amana ARS2667BC Ref - SXS/I&W
Amana ARS2667BS Ref - SXS/I&W
Amana ARS2667BW Ref - SXS/I&W
Amana ARS266KBB Ref - SXS/I&W
Amana ARS266KBC Ref - SXS/I&W
Amana ARS266KBW Ref - SXS/I&W
Amana ARS266RBB Ref - SXS/I&W
Amana ARS266RBC Ref - SXS/I&W
Amana ARS266RBW Ref - SXS/I&W
Amana ARS266XAW Ref - SXS/I&W
Amana ARS266ZBB  Ref - SXS/I&W
Amana ARS266ZBC  Ref - SXS/I&W
Amana ARS266ZBS  Ref - SXS/I&W
Amana ARS266ZBW  Ref - SXS/I&W
Amana ARS2760BW Ref - SXS/I&W
Amana ARS635 Range - S/c S/i Ddraft Ele
Amana ARS635W Range - S/c S/i Ddraft Ele
Amana ARS636E Range - S/c S/i Ddraft Ele
Amana ARS636WW Range - S/c S/i Ddraft Ele
Amana ARS8265BB  Ref - SXS/I&W
Amana ARS8265BC  Ref - SXS/I&W
Amana ARS8265BS  Ref - SXS/I&W
Amana ARS8265BW  Ref - SXS/I&W
Amana ARS8267BB  Ref - SXS/I&W
Amana ARS8267BC  Ref - SXS/I&W
Amana ARS8267BS  Ref - SXS/I&W
Amana ARS8267BW  Ref - SXS/I&W
Amana ARS9107AS Ref - SXS/I&W
Amana ARS9107AW Ref - SXS/I&W
Amana ARS9167AB Ref - SXS/I&W
Amana ARS9167AC Ref - SXS/I&W
Amana ARS9167AS Ref - SXS/I&W
Amana ARS9167AW Ref - SXS/I&W
Amana ARS9168AB Ref - SXS/I&W
Amana ARS9168AC Ref - SXS/I&W
Amana ARS9168AS Ref - SXS/I&W
Amana ARS9168AW Ref - SXS/I&W
Amana ARS9169AS Ref - SXS/I&W
Amana ARS9265BB  Ref - SXS/I&W
Amana ARS9265BC  Ref - SXS/I&W
Amana ARS9265BW  Ref - SXS/I&W
Amana ARS9266BS  Ref - SXS/I&W
Amana ARS9268BB  Ref - SXS/I&W
Amana ARS9268BC  Ref - SXS/I&W
Amana ARS9268BW  Ref - SXS/I&W
Amana ARS9269BS  Ref - SXS/I&W
Amana ARSE664BB Ref - SXS/I&W
Amana ARSE664BC Ref - SXS/I&W
Amana ARSE664BS Ref - SXS/I&W
Amana ARSE664BW Ref - SXS/I&W
Amana ARSE665BB  Ref - SXS/I&W
Amana ARSE665BC  Ref - SXS/I&W
Amana ARSE665BS  Ref - SXS/I&W
Amana ARSE665BW  Ref - SXS/I&W
Amana ARSE667BB Ref - SXS/I&W
Amana ARSE667BC Ref - SXS/I&W
Amana ARSE667BS Ref - SXS/I&W
Amana ARSE667BW Ref - SXS/I&W
Amana ARSE66MBB Ref - SXS/I&W
Amana ARSE66MBC Ref - SXS/I&W
Amana ARSE66MBW Ref - SXS/I&W
Amana ARSE66ZBB  Ref - SXS/I&W
Amana ARSE66ZBC  Ref - SXS/I&W
Amana ARSE66ZBS  Ref - SXS/I&W
Amana ARSE66ZBW  Ref - SXS/I&W
Amana ARSE67RBB  Ref - SXS/I&W
Amana ARSE67RBC  Ref - SXS/I&W
Amana ARSE67RBS  Ref - SXS/I&W
Amana ARSE67RBW  Ref - SXS/I&W
Amana ART1805BC Ref - Top Mount
Amana ART1805BW Ref - Top Mount
Amana ART2105BB Ref - Top Mount
Amana ART2105BC Ref - Top Mount
Amana ART2105BW Ref - Top Mount
Amana ART2107BB Ref - Top Mount
Amana ART2107BC Ref - Top Mount
Amana ART2107BS Ref - Top Mount
Amana ART2107BW Ref - Top Mount
Amana ART2127AB Ref - Top Mount
Amana ART2127AC Ref - Top Mount
Amana ART2127AS Ref - Top Mount
Amana ART2127AW Ref - Top Mount
Amana ART2129ABR Ref - Top Mount
Amana ART2129ACR Ref - Top Mount
Amana ART2129ASR Ref - Top Mount
Amana ART2129AWR Ref - Top Mount
Amana ART2527AB Ref - Top Mount
Amana ART2527AC Ref - Top Mount
Amana ART2527AW Ref - Top Mount
Amana ART5400L Range - Std Mwave Ele
Amana ART5400W Range - Std Mwave Ele
Amana ART6000L Range - S/c S/i Ddraft Gas
Amana ART6000W Range - S/c S/i Ddraft Gas
Amana ART6001L Range - S/c S/i Ddraft Gas
Amana ART6001W Range - S/c S/i Ddraft Gas
Amana ART6002L Range - S/c S/i Ddraft Gas
  #2 (permalink)
Old 07-25-2009, 02:11 PM
Senior Expert
APP Volunteer
magician59 will become famous soon enough
Default
In the cooling mode you should see a uniform light frost on the evaporator coil If you don't, you either have a refrigerant restriction or a leak.
  #3 (permalink)
Old 07-25-2009, 07:19 PM
Junior Member
Default
I re-plugged the unit in about 2.00pm and just now (10:30pm) checked and the freezer coils does have frost on them. I have the freezer unit set at 5 and it is 20 degrees right now. Anything else should I check?
  #4 (permalink)
Old 07-26-2009, 06:28 AM
Junior Member
Default
Last night I turned the temp. control to 6 on both refrig & freezer. This morning the refrig. temp was 32 degrees and the freezer is at 16. I am going to turn the refrig temp back to 5 and turn up the freezer all the way up to 7. Both refrig and freezer are empty. If the refrig side temps are ok and the freezer side temps are not cold enough what should I do next?
  #5 (permalink)
Old 07-26-2009, 02:47 PM
Senior Expert
APP Volunteer
Default
The refrigerator temperature is totally dependent on the operation of the freezer (unless you have one of those "all refrig" units, or a double compressor system, such as Sub Zero). If the temps are too high, you either have a defrost problem, causing excessive icing in the freezer; low refrigerant caused by a leak in the sealed system; or some kind of air flow problem. Post your temps and report what you observe in the evaporator (a light frosting is normal--snow is not).
  #6 (permalink)
Old 08-03-2009, 09:07 AM
Junior Member
Default
Thanks for all your help. It was the compressor. I was going to cost about 600.00 to fix with only a year warranty. Since the refrigerator is 9 years old I decided to just buy a new refrigerator.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
side by side refrigerator - fridge side freezing food, water coming out of freezer bomb Refrigerator & Freezer Repair 8 08-30-2011 01:58 PM
whirpool side by side lights don't work in refrigerator side and also digital temp dvite Refrigerator & Freezer Repair 5 02-02-2011 04:47 PM
No cool air in the freezer side and refrigrator side whirlpool09 Refrigerator & Freezer Repair 1 02-18-2009 05:16 AM
Refridgerator side will not cool. Freezer side OK SMWOLD Refrigerator & Freezer Repair 1 09-07-2008 09:31 AM
Side-by-Side: refrig warm, freezer cool tkrotchko Refrigerator & Freezer Repair 4 10-28-2007 07:19 PM
