Discuss
Honeywell Compact Cube Fridge
 in
Refrigerator & Freezer Repair
I have a 1.8 compact fridge by Honeywell that's not working. The fans vibrate but does not turn and the
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Honeywell Compact Cube Fridge
  #1 (permalink)
Old 07-25-2009, 04:28 AM
Junior Member
Coxy is on a distinguished road
Talking Honeywell Compact Cube Fridge
Model Number: 88031   Brand: -other-   Age: Less than 1 year
The fans vibrate but does not turn and the inside LED flickers.
The fridge makes a ticking noise but will not work.
Is there a test I can do with my meter to narrow it down?
Ads By Google
Related Models
Whirlpool 880652124P0 30" Electric Ceran Freestanding Range Standard Clean Oven
Whirlpool 8811W00
Whirlpool 8811^00
Whirlpool 8812W00
Whirlpool 8812^00
Whirlpool 8814W00
Whirlpool 8814^00
Whirlpool 8815W00
Whirlpool 8815^00
Jenn-Air 88168 Range - F/s Std Ddraft Ele
Jenn-Air 88169 Range - F/s Std Ddraft Ele
Whirlpool 8816W00
Whirlpool 8816^00
Jenn-Air 88170 Range - F/s Std Ddraft Ele
Whirlpool 8817W00
Whirlpool 8817W10
Whirlpool 8817^00
Jenn-Air 88186 Misc / Accessory
Whirlpool 8818W00
Whirlpool 8818^00
Whirlpool 8819W00
Whirlpool 8819^00
Whirlpool 8820W00
Whirlpool 8820^00
Whirlpool 8822W00
Whirlpool 8822^00
Jenn-Air 88353 Surface Unit - Ele
Jenn-Air 88353-8 Surface Unit - Ele
Jenn-Air 88368 Range - F/s Std Ddraft Ele
Jenn-Air 88369 Range - F/s Std Ddraft Ele
Jenn-Air 88370 Range - F/s Std Ddraft Ele
Jenn-Air 88371 Range - F/s Std Ddraft Ele
Jenn-Air 88372 Range - F/s Std Ddraft Ele
Jenn-Air 88889 Surface Unit - Ele
Jenn-Air 88890 Surface Unit - Ele
Jenn-Air 88891 Surface Unit - Ele
Magic Chef 88FK-1 Surface Unit - Ele
Magic Chef 88FK-2 Surface Unit - Ele
Magic Chef 88FK-6 Surface Unit - Ele
Magic Chef 88FN-1
Magic Chef 88FN-2 Surface Unit - Ele
Magic Chef 88FN-6 Surface Unit - Ele
Magic Chef 88LK-6 Surface Unit - Ele
Magic Chef 88LN-6 Surface Unit - Ele
Amana 890.000 Range - S/c S/i Ddraft Gas
Amana 890.001 Mwave - Family Size (60 Hz)
Amana 890.301 Mwave - Family Size (60 Hz)
Amana 890.302 Mwave - Family Size (60 Hz)
Amana 890.304 Mwave - Family Size (60 Hz)
Jenn-Air 89353 Surface Unit - Ele
Jenn-Air 89353-8 Surface Unit - Ele
Jenn-Air 89353-C Surface Unit - Ele
Amana 894.304 Mwave - Family Size (60 Hz)
Amana 894.307 Mwave - Family Size (60 Hz)
Amana 896.A Mwave - Family Size (60 Hz)
Amana 896.B Mwave - Family Size (60 Hz)
Whirlpool 8963L00
Whirlpool 8963L30
Jenn-Air 89889 Surface Unit - Ele
Jenn-Air 89889-C
Jenn-Air 89890 Surface Unit - Ele
Jenn-Air 89890-C Surface Unit - Ele
Jenn-Air 89891 Surface Unit - Ddraft Ele
Jenn-Air 89891-C
Magic Chef 89L-4 Surface Unit - Ele
Magic Chef 89L-6 Surface Unit - Ele
Whirlpool 8AC2504XS0
Whirlpool 8ACE07LD0
Whirlpool 8BLGR5636JQ0
Whirlpool 8BLGR5636JQ1 29"gas Dryer
Whirlpool 8CACM07DD0
Whirlpool 8CACM07DD1
Whirlpool 8CACM07ND0
Whirlpool 8CACM10DD1
Whirlpool 8ED0GTKXKQ00
Whirlpool 8ED0GTKXKQ01 Refrigerator
Whirlpool 8ED0GTKXKQ02 Refrigerator
Whirlpool 8ED0GTKXKT00
Whirlpool 8ED0GTKXKT01 Refrigerator
Whirlpool 8ED0GTKXKT02 Refrigerator
Whirlpool 8ED0WTKXKT00
Whirlpool 8ED0WTKXKT01
Whirlpool 8ED0WTKXKT02 Refrigerator
Whirlpool 8ED20TKXDN00
Whirlpool 8ED20TKXDN01
Whirlpool 8ED20TKXDN02
Whirlpool 8ED20TKXDW00
Whirlpool 8ED20TKXDW01
Whirlpool 8ED20TKXDW02
Whirlpool 8ED20TKXFN00
Whirlpool 8ED20TKXFN01
Whirlpool 8ED20TKXFN02
Whirlpool 8ED20TKXFN03
Whirlpool 8ED20TKXFN04
Whirlpool 8ED20TKXFW00
Whirlpool 8ED20TKXFW01
Whirlpool 8ED20TKXFW02
Whirlpool 8ED20TKXFW03
Whirlpool 8ED20TKXFW04
Whirlpool 8ED20ZKXAG00
Whirlpool 8ED20ZKXAG02
Whirlpool 8ED20ZKXAN00
Whirlpool 8ED20ZKXAN02
Whirlpool 8ED20ZKXAW00
Whirlpool 8ED20ZKXAW01
Whirlpool 8ED20ZKXAW02
Whirlpool 8ED20ZKXBG00
Whirlpool 8ED20ZKXBN00
Whirlpool 8ED20ZKXBW00
Whirlpool 8ED20ZKXDG00
Whirlpool 8ED20ZKXDG01
Whirlpool 8ED20ZKXDN00
Whirlpool 8ED20ZKXDN01
Whirlpool 8ED20ZKXDN02
Whirlpool 8ED20ZKXDN03
Whirlpool 8ED20ZKXDW00
Whirlpool 8ED20ZKXDW01
Whirlpool 8ED20ZKXDW02
Whirlpool 8ED20ZKXDW03
Whirlpool 8ED20ZKXFN00
  #2 (permalink)
Old 07-25-2009, 06:49 AM
Senior Expert
APP Volunteer
richappy is a name known to all
Default
I would pull the back panel off the freezer and check why the fgan will not turn.
__________________
  #3 (permalink)
Old 07-25-2009, 07:11 AM
Junior Member
Default
all fans not working, only osillating.
Inside light osillates until temp select button turned off, then light is steady. Its 12Vac stepped down to 12VDC
  #4 (permalink)
Old 07-25-2009, 07:27 AM
Junior Member
Default
just unhooked 12V harness to temp control and all fans and everything is working except of course the temp control and light that is attached to it
  #5 (permalink)
Old 07-25-2009, 08:50 AM
Senior Expert
APP Volunteer
Default
Seems like the fan and lite will not work when the compressor is hooked up, is this true?
__________________
  #6 (permalink)
Old 07-25-2009, 11:11 AM
Junior Member
Default
I did some probing with my meter. Some of the plugins on the DC side is only getting 6+- volts, where on the board it says 12V.
Looks like I'm not getting the proper voltage on the DC side. all the wires that go back into the fridge are off this DC board.
If I can't fix it I will try and make run off batteries.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
compact washer jimlorton Washer Repair 0 02-20-2010 01:02 PM
Ram does not compact lgreganti Trash Compactor Repair 0 01-18-2010 07:01 AM
compact refrigerator Jolds Refrigerator & Freezer Repair 0 08-21-2009 07:43 AM
compactor will not compact JFOSTER Trash Compactor Repair 1 05-09-2009 02:13 PM
fridge dispenses crushed rather than cube ice markduffy Refrigerator & Freezer Repair 1 02-04-2009 05:14 PM
