Ice dispenser ok water not working. water ok up to valve solenoids ok. removed front trim, looking for some kind of micro switch found pc board. i stopped. what should i be looking for or check. thank you :confused:
Originally Posted by: tishie Ice dispenser ok water not working. water ok up to valve solenoids ok. removed front trim, looking for some kind of micro switch found pc board. i stopped. what should i be looking for or check. thank you :confused: i have ice. can i swap the solenoids to see if maybe thats my eprobleum
Groups: APP Team
