I have a GE TFF24ZA frig making a high pitched noise. The noise stops when I disconnect Clip - Harness Part Number: AP2058238 on left front corner of the freezer. What does Clip - Harness Part Number: AP2058238 feed so I can replace it? How dow I get to that part?
Does this noise come from the freezer? Would this noise stop when the compressor stooped? If it would, check the evaporator fan motor (inside the freezer). - The evaporator fan motor Part number: AP2639776
