Discuss
no water in icetray
 in
Refrigerator & Freezer Repair
No water flowing to ice tray. The ice maker works when I put water in the tray. Water dispenser in
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » no water in icetray
  #1 (permalink)
Old 01-07-2008, 11:47 AM
jam jam is offline
Junior Member
jam is on a distinguished road
Unhappy no water in icetray
Model Number: KSRB25FRBXOO   Brand: Kitchen Aid   Age: 1 - 5 years
No water flowing to ice tray. The ice maker works when I put water in the tray. Water dispenser in door works. Where do I begin to check for freezing in the line? Most of the tubing is covered. Do I have to pull the refridgerator away from the wall? Is the water valve for the ice maker in the back? I would love to have a diagram of the parts and their loactions.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 01-07-2008, 01:15 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Open the freezer door and view the "status" LED on the right side.
Press in the emitter flapper door on the left side to unblock the optics beam and view the "status" LED.
Post you findings.
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 01-08-2008, 09:49 AM
jam jam is offline
Junior Member
Default
The red light is on continuously.
  #4 (permalink)
Old 01-08-2008, 12:07 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Next step:
Remove the ice maker and check the water feeding tube for freezing.
If it's frozen, defrost it using a hair dryer.
If it's frozen, then the water inlet valve has to be replaced.
- The part number for the water inlet valve is AP3160649
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
