I have an ice maker that will make ice for the first cycle and then shots off and then gives the blinking light code of 1 blink per second. accordign to the manuals and codes I have found on line it is the code for the bin thermasistor. I bought a new one and have installed and the same thing happens, so it was not the problem.
any ideas?
I also have just cleaned it and this also made no difference.
it turns on, water works, it makes ice, then after 1 cycle(20 minutes) it stops making ice and the red light blinks. according to the ,manual and the servoice amnual I have found the bin therasistor is the only item to turn off the machine all ?????
help
