| » Freezer Works/Fridge Does not |
Model Number: ARB2217CSL Brand: Amana Age: 1 - 5 years
Amana bottom freezer/fridge top model.
Freezer works fine - cold as it should be. Air blows around freely in the freezer. However fridge on top is not cooling. I pulled the back inside panel off the freezer and there was considerable frost (white flakes). It was peculiar though, in that there was a very distinct line of frost on the coils/fins. Below the line was heavily frosted, above the line (closest to the fan) was completely frost free. So I'm thinking the defrost timer or defrost unit, correct? But what is this very distinct line of frost telling me? Could it indicate which part is bad? Ads By Google Related Models |
Did you see any frost on the back panel before you removed it?
What was a percentage of frost on the evaporator coil? Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
Thanks for reply.
If you mean on the inside wall of the freezer against the coils - no, not a considerable amount of frost. Maybe ever so slightly if I scratched a fingernail against it, but not noticable. For your second question - The bottom half of the coils were 90-100% covered in frost - inbetween and on outside surface. The top half of the coils were virtually free of any ice or frost. There was a very distinct demarcation line between the top and bottom - below the line was the frost, above the line no frost. Since I posted, I "defrosted" the coils and the refrig has returned to cooling normally. I'm watching the coils closely to see if frost continue to build up - in the day since I defrosted no frost has returned but I think it is too early to really tell. I still think based on what happened something is not functioning correctly. Thanks for any added input you may have. |
One of possibilities is - the compressor has a low capacity. Another word the pressure in the system goes up and down.
If this is right, then the compressor has to be replaced. Gene.
__________________
The evaporator coil should be normally covered in thin frost completely.
If it has completely blocked with frost, then the problem is a faulty defrost. If it has a pretty valuable area free of frost and snow, it means insufficient amount of the Freon circulating through the system due to a leak somewhere or a faulty compressor. Best regards. Gene.
__________________
| Display Modes | |
| Freezer works but not fridge Need Help!!!!! | msshottet | Refrigerator & Freezer Repair | 9 | 10-16-2009 12:38 PM |
| GE fridge, Freezer works, fridge dont.. need repair manual | kattkrzkatt | Refrigerator & Freezer Repair | 1 | 11-29-2008 09:45 AM |
| Freezer works but Fridge does not | parablaze | Refrigerator & Freezer Repair | 0 | 07-14-2008 03:23 PM |
| freezer works, fridge doesn't | walt3 | Refrigerator & Freezer Repair | 1 | 06-23-2008 10:05 PM |
| Freezer works not fridge. | apadulo | Refrigerator & Freezer Repair | 1 | 12-10-2007 01:02 PM |
