| » Kenmore Coldspot - water dispenser not working |
Model Number: 106.58585890 Brand: Kenmore Age: More than 10 years
The water dispenser on my refrigerator is not working. So far I have confirmed there is no blockage in the door by removing the water line below the door and moving air through the line and out the water spigot. I have also confirmed there is no blockage in the water line between the water valve in the back of the fridge and the where the water line reaches the bottom of the freezer door. I hear a buzzing sound when pressing the water dispenser. The ice maker works perfectly. I am assuming that I need to replace the water valve assembly in the bottom rear of the fridge. From what I have been able to find on the net so far, that is most likely the culprit but I could use some expert advice just in case my novice senses are wrong. Also I found part #4389177 on the sears parts direct website - is this the correct part? And how do I hook up the quick connects on this part with the screw on connectors from my old water lines?
Ads By Google Related Models Last edited by nails1 : 07-21-2009 at 12:23 AM. |
Sounds like the problem is a bad water inlet valve, but before order the part I would do two things: make sure the water reservoir in the refrigerator (behind the bottom drawer) is not frozen and check if 120 VAC coming to the water valve solenoid while the water dispenser calls for water.
If there is nothing wrong then the water inlet valve is the culprit. The part number you posted is correct. It comes with the installation instructions. - The water inlet valve Part number: 4389177 Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
__________________
Thank you for good words. I'm glad you were able to fix it. Thank you for the feed back and good luck with your refrigerator.
__________________
| Display Modes | |
| Kenmore Refrigerator front water dispenser not working | neustkg | Refrigerator & Freezer Repair | 13 | 08-15-2011 09:51 AM |
| Kenmore water dispenser not working after filter change | MikeJFlorida | Refrigerator & Freezer Repair | 1 | 09-19-2010 06:41 PM |
| Changing Water Filter in Kenmore Coldspot | KiaEarp | Refrigerator & Freezer Repair | 1 | 03-06-2010 04:33 PM |
| water lines to hook up to the water valve on a kenmore coldspot | simonf22 | Refrigerator & Freezer Repair | 0 | 12-17-2009 12:16 PM |
| Kenmore Coldspot 106: Ice Maker not Drawing Water | andrewjhalstead | Refrigerator & Freezer Repair | 0 | 10-10-2009 02:58 PM |
