achutegui
#1 Posted : Monday, July 20, 2009 7:46:10 PM(UTC)
achutegui
I am a student and I charged a home refrigerator that wasn't cooling only 1/4 of the evaporator was cold but first I changed the filter drier and after that it is doing the same thing....is there a chance that the compressor is not pumping properly?
#2 Posted : Tuesday, July 21, 2009 12:31:19 PM(UTC)
What is the model number of the refrigerator?
How did you replace the filter-dryer?
How did you charged the system?
What type of Freon did you use?
achutegui
#3 Posted : Wednesday, July 22, 2009 10:07:33 AM(UTC)
achutegui
Well first I don't have the model #
I braced a new filter drier but defore I did this and when the system was still open at te metering device and the liquid line I put some pressure on the system to see it was't plug and air was coming on both sides then I braced the filter drier and pressure tested it again and it had no leaks then I vaccum the system and put 4.5 oz of 134a refrigerant using a dial a charge cylinder and it is not cooling only have of the evaporator coil is cold
what I think is that the compressor is not pumping correctly but I can't check the discharge pressure because I did't put a line tap on the discharge line.:confused:
#4 Posted : Wednesday, July 22, 2009 12:13:18 PM(UTC)
The name plate with the model number and amount of Freon being charged in the system should be in the fresh food compartment. Possible you undercharge it. Also you have to check the pressure on both sides using a pressure gauges. It helps to check the correct charge and let you see how the compressor works.
P.S. In most states such job requires a special license.
Monogram side-by-side not cooling - Ice builds up on Evaporator Fan (Refrigerator & Freezer Repair)
by 95ireland 3/11/2024 6:22:51 PM(UTC)
Mabe MBC12GAZASS Not Cooling (Refrigerator & Freezer Repair)
by MKDrepair 2/5/2024 5:57:08 AM(UTC)
GE GSS23QSTA not cooling after power outage (Refrigerator & Freezer Repair)
by sfarid123 12/19/2023 7:39:47 AM(UTC)
LG Refrigerator not cooling; compressor clicking. (Refrigerator & Freezer Repair)
by pmrowley 11/8/2023 7:07:53 AM(UTC)
Ge Monogram Integrated Top/Bottom Not Cooling ZICP360NXLH (Refrigerator & Freezer Repair)
by grundyv2 10/7/2023 12:48:51 PM(UTC)
GE botom freezer not cooling (Refrigerator & Freezer Repair)
by Dieselista 10/6/2023 5:39:30 PM(UTC)
Whirlpool WRV986FDEM00 is not cooling (Refrigerator & Freezer Repair)
by Find a fix 9/23/2023 4:03:34 AM(UTC)
Jenn-air refrigerator not cooling (Refrigerator & Freezer Repair)
by pke 9/20/2023 4:18:40 PM(UTC)
Samsung family hub freezer not cooling (Refrigerator & Freezer Repair)
by foster1447 8/20/2023 2:36:12 PM(UTC)
Whirlpool Refrigerator cooling intermittently or not cooling at all (Refrigerator & Freezer Repair)
by lsitnj 8/12/2023 3:39:26 PM(UTC)
Freezer is not cooling, fan is not working, light not on, NEW control board; GE fridge GSS25GSHJCSS (Refrigerator & Freezer Repair)
by Guest 8/6/2023 3:06:23 PM(UTC)
Refrigerator working, freezer not cooling (Refrigerator & Freezer Repair)
by Guest 7/11/2023 6:24:54 AM(UTC)
Kenmore Coldspot Model 106 not cooling (Refrigerator & Freezer Repair)
by wdeagle 7/2/2023 8:54:15 AM(UTC)
Maytag fridge side not cooling. (Refrigerator & Freezer Repair)
by Ropavejero 6/23/2023 4:37:10 PM(UTC)
New GE refrigerator not cooling to set temp of 35 (Refrigerator & Freezer Repair)
by VarMan 6/16/2023 5:05:53 PM(UTC)
