Help!
my side by side fridge/freezer with water and ice dispensor is freezing in the lower part of freezer but not the top part,also the fridge side is freezing the produce. happened before so I changed the top temp senor and the thermistor on the evap. and was good for about 1 1/2 months. Now it is happening again. Should I have changed all temp. sensors or the main board,help!
Pull the freezer back panel and descibe the frost pattern, heavy frost all over, or light frost just at the bottom of the coils.
hi, the freezer evap froze lots all over coils last time so I replaced the thermister on the evap. and the temp sensor on the top of freezer part. was good for about 1 1/2 months now evap freezing all over again and top part of freezer area not freezing but the fridge side where crispers are r freezing the produce. should I replace main board or all the rest of temp sensors along with the defrost heater?
thks
Inspect the defrost heater, most probable failure.
thanks for reply how do i see if the defrost heater is bad as i am not at the location and have to order parts if needed. just in case heater is good what else could cause this problem thks
I am confused, are the freezer coils frozen all over, or just partially. A stabilizeds freezer temperature reading would be helpfull.
