| » Kenmore/Whirlpool new compressor doesnt turn off |
Model Number: 106.54692300 Brand: Kenmore Age: 5 - 10 years
5.5 yr old fridge Kenmore 106.54692300 (Whirlpool). Coils were dusty, but compressor unit failed hard in one day, no warm temp, etc.
Shouldn't have but I spent too much to have someone come replace compressor here in California. Original compressor is Embraco EGZ 90HLP, the new compressor is Embraco FF 10HBX. The spec sheet I have on the FF 10HBX shows that it has approximate 1/5 HP. Can't tell what the difference is from the Embraco site: http://www.embraco.com/ingles/produtos/02003.pdf It's been three days and I have heard compressor turn off only a couple times yesterday. The temp is the ref section varies from 35-39 degrees. The Ice maker has just about finished filling the whole tray, but refrig is not cycling off. [Should the fridge stay on constantly to fill the ice tray?] If the thermostat was bad, then wouldn't the refrig section go down to 30 deg? BTW, my control board for turning ref of/on and changing freezer, ref temps went out last year. Controls levels are stuck at 4 for freezer (midrange) and stuck at 5 (one level above midrange) for the refrig. On sears parts direct, the compressor listed is a comparable substitute. So, could the refrigerant level be low/high or the new compressor be a smaller size than original, 1/5 vs 1/4 HP? It is only 81 degrees Far in the house. Related Models |
Why do mention airflow? The refrig section temps are OK, the freezer temps are -8 to +6. With freezer control stuck in the middle, should freezer not go below 0? Is the thermostat controlling freezer section? If so, maybe thermostat is faulty causing continuous operation?
Without looking at the unit, your problem might be refrigerant purity, the cold air from the freezer is not cold enough to turn off the differential cold control. Either that, or you have some partial restriction in the airflow. If I where there, I would carefully inspect the evaporator coil frost pattern for incomplete frost and measure the coil temperature with my digital thermometer.
__________________
| Display Modes | |
| Kenmore dryer timer doesnt work | treed | Dryer Repair | 1 | 05-25-2009 07:48 AM |
| dryer comes on but drum doesnt turn | Brian Kelley | Dryer Repair | 1 | 02-28-2009 05:06 PM |
| Dishwasher doesnt clean and arm doesnt turn. | sjskee2 | Dishwasher Repair | 3 | 01-09-2009 05:40 PM |
| Cold Control shuts off compressor when switched 'off' but won't turn back on... | 80sGuy | Refrigerator & Freezer Repair | 4 | 09-13-2008 02:38 PM |
| Dryer drum doesnt turn | eric1025 | Dryer Repair | 3 | 10-07-2007 03:47 AM |
