I Purchased A New Wiring Harness For The Freezer Door (p/n 2187667) And Removed The Front Panel But Unable To See How The Front Door Ice And Water Dispenser Assembly Is Removed. The Wiring Harness Originally On The Door Has Been Repaired (wires Reconnected And Or Soldered) Several Times. The Unit Works Great But A Flaw In The Design Of The Wire Harness Routing At Hing Point. Any Help On Replacement Of The Harness Would Be Greatly Appreciated.
