Discuss
fridge wont freeze or cool
 in
Refrigerator & Freezer Repair
fans are working, coils have no frost on them. compressor is working. cleaned out years of dust buildup from the
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » fridge wont freeze or cool
  #1 (permalink)
Old 07-19-2009, 10:09 AM
nrg nrg is offline
Junior Member
nrg is on a distinguished road
Default fridge wont freeze or cool
Model Number: SXD22S2W   Brand: Amana   Age: 5 - 10 years
fans are working, coils have no frost on them. compressor is working. cleaned out years of dust buildup from the bottom of the fridge.
i'm not sure on the actual temp of the fridge. ice cream is melted and beer is mild cold. 50f freezer, 70f fridge side probably
one thing i really notice is that it's extremely HOT to the touch on the side of the fridge on the outside. Freezer sides and the center divider that meets the door.
could the defroster be stuck ON and keeping the coils from freezing?
faulty defrost timer?
thanks.
edit: ok, it has been running for two hours. frost on coils but not cold enough. the same ice is now frozen but it shouldn't take 2hours to make ice.
sides are still hot.
edit2: ok so i found the condenser fan not running. that explain the hotness to the sides.
do i just change out the fan motor or is there a relay that went bad? thanks
Related Models
Amana SXD22S2W REF - SXS/I&W
Amana SXD23VE REF - SXS/I&W
Amana SXD23VL REF - SXS/I&W
Amana SXD23VW REF - SXS/I&W
Amana SXD25AE REF - SXS/I&W
Amana SXD25AL REF - SXS/I&W
Amana SXD25AW REF - SXS/I&W
Amana SXD25J REF - SXS/I&W
Amana SXD25JB REF - SXS/I&W
Amana SXD25JP REF - SXS/I&W
Amana SXD25M2L REF - SXS/I&W
Amana SXD25M2W REF - SXS/I&W
Amana SXD25MB2L REF - SXS/I&W
Amana SXD25MB2W REF - SXS/I&W
Amana SXD25MBG REF - SXS/I&W
Amana SXD25MBL REF - SXS/I&W
Amana SXD25MBW REF - SXS/I&W
Amana SXD25MG REF - SXS/I&W
Amana SXD25ML REF - SXS/I&W
Amana SXD25MP2L REF - SXS/I&W
Amana SXD25MP2W REF - SXS/I&W
Amana SXD25MPG REF - SXS/I&W
Amana SXD25MPL REF - SXS/I&W
Amana SXD25MPW REF - SXS/I&W
Amana SXD25MW REF - SXS/I&W
Amana SXD25N2E REF - SXS/I&W
Amana SXD25N2L REF - SXS/I&W
Amana SXD25N2W REF - SXS/I&W
Amana SXD25NE REF - SXS/I&W
Amana SXD25NL REF - SXS/I&W
Amana SXD25NP2E REF - SXS/I&W
Amana SXD25NP2L REF - SXS/I&W
Amana SXD25NP2W REF - SXS/I&W
Amana SXD25NPE REF - SXS/I&W
Amana SXD25NPL REF - SXS/I&W
Amana SXD25NPW REF - SXS/I&W
Amana SXD25NW REF - SXS/I&W
Amana SXD25QA3E REF - SXS/I&W
Amana SXD25QA3L REF - SXS/I&W
Amana SXD25QA3W REF - SXS/I&W
Amana SXD25S2E REF - SXS/I&W
Amana SXD25S2L REF - SXS/I&W
Amana SXD25S2W REF - SXS/I&W
Amana SXD26VE REF - SXS/I&W
Amana SXD26VL REF - SXS/I&W
Amana SXD26VW REF - SXS/I&W
Amana SXD27NE REF - SXS/I&W
Amana SXD27NL REF - SXS/I&W
Amana SXD27NW REF - SXS/I&W
Amana SXD27Q2E REF - SXS/I&W
Amana SXD27Q2L REF - SXS/I&W
Amana SXD27Q2W REF - SXS/I&W
Amana SXD27TE REF - SXS/I&W
Amana SXD27TL REF - SXS/I&W
Amana SXD27TW REF - SXS/I&W
Amana SXD322L REF - SXS/I&W
Amana SXD322S2L REF - SXS/I&W
  #2 (permalink)
Old 07-19-2009, 04:57 PM
Senior Expert
APP Volunteer
richappy is a splendid one to behold
Default
Put a portable fan on the compressor till you can order one on this site.
__________________
  #3 (permalink)
Old 07-19-2009, 07:48 PM
nrg nrg is offline
Junior Member
Default
yea that's what i have now. it's been on there for the past three hours but the freezer isn't sub zero and the fridge part isn't any colder.
on the coils, only the ends have frost.
edit: i did some cleaning around the back area and the fan. i got the fan to spin. everything seems to be working correctly. i might have to give it 24hrs to see if it works 100%.
  #4 (permalink)
Old 07-20-2009, 02:12 AM
Senior Expert
APP Volunteer
Default
Lots of times when compressors overheat, the compressor will get damaged and become ineficient and leak refigerant internally. A pro. could determine if a leak or bad compressor. Sorry, sounds like new compressor time or new fridg.
__________________
  #5 (permalink)
Old 07-20-2009, 05:12 PM
nrg nrg is offline
Junior Member
Default
i've had a fan in the rear of the fridge for over 24hrs. the freezer is freezing ice, ice cream isn't melting. frost on the whole coil. the fridge is cold and the mountains on the coors Light cans are blue.
the condenser fan decided to stop working last night, this is why the fan is there now. so i just need to order a new fan motor.
edit: i forgot to mention that everything works fine at the max settings of 7. the fridge/freezer use to work perfectly fine at 4-5. I have set it back to 5 in the past few hours and the ice was melted..
is this an issue with a main board or weak compressor?
  #6 (permalink)
Old 07-20-2009, 06:32 PM
Senior Expert
APP Volunteer
Default
Measure the back freezer wall temperature and post, you might have system problems.
__________________
  #7 (permalink)
Old 07-22-2009, 12:08 AM
nrg nrg is offline
Junior Member
Default
fridge and freezer settings are at 5 and everything seems to be normal with temporary fan in place at the condenser. i'm going to order a new condenser fan.
  #8 (permalink)
Old 07-22-2009, 01:45 AM
Senior Expert
APP Volunteer
Default
Good work, thanks for the feedback.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE Fridge Freezer wont freeze EMuel Refrigerator & Freezer Repair 1 02-17-2010 04:28 AM
under counter fridge wont cool ebin Refrigerator & Freezer Repair 0 08-28-2009 05:51 PM
Freezer thawing, cool air, no freeze skykevver Refrigerator & Freezer Repair 2 06-10-2009 05:31 PM
Fridge Wont Cool B-BALL2 Refrigerator & Freezer Repair 2 09-22-2008 11:54 AM
Wont Defrost And Fridge Not Cool RDWEDEL Refrigerator & Freezer Repair 1 04-10-2008 06:43 PM
