akieslich
#1 Posted : Saturday, July 18, 2009 5:01:00 AM(UTC)
akieslich
no temperature; freezer compartment dropped down to 65 degrees and no refrigeration on refrigeration side. the fan was removed and replaced and compressor still did not come on What next? Is it worth fixing?
#2 Posted : Saturday, July 18, 2009 5:30:00 AM(UTC)
What's running, anything? If nothing running, you may have a stuck defrost timer, if your fridg has one, or a blown out adaptive defrost pc board in the fridg control housing. If you have a meter, check for voltage to the compressor, if none, one of the above items is probably bad either that or the cold control.
Compressor Start Device constantly needs replacing (Refrigerator & Freezer Repair)
by norsemen 3/11/2024 2:17:34 PM(UTC)
Compressor & condenser fan not running - low voltage, start relay ok (Refrigerator & Freezer Repair)
by Guest 1/17/2024 11:51:38 AM(UTC)
Amana compressor issues (Refrigerator & Freezer Repair)
by Guest 1/1/2024 12:42:43 PM(UTC)
refrigerator compressor clicking off (Refrigerator & Freezer Repair)
by rleescott 12/22/2023 4:57:43 AM(UTC)
LG Refrigerator not cooling; compressor clicking. (Refrigerator & Freezer Repair)
by pmrowley 11/8/2023 7:07:53 AM(UTC)
Refrigerator inverter compressor not starting (Refrigerator & Freezer Repair)
by Guest 11/1/2023 4:24:39 PM(UTC)
Need help with cut in cut out Old McQuay freezer w/Hupp compressor (Refrigerator & Freezer Repair)
by Deserttoad 5/5/2023 2:39:37 PM(UTC)
Not defrosting and motor/compressor running constantly (Refrigerator & Freezer Repair)
by egizzi 3/23/2023 7:05:21 PM(UTC)
compressor start relay question (Refrigerator & Freezer Repair)
by Guest 10/16/2022 2:45:39 AM(UTC)
Noisy Commercial Refigerator Compressor (Refrigerator & Freezer Repair)
by djsource 9/18/2022 12:24:54 PM(UTC)
Embraco EMI30HER Compressor - is it toast? (Refrigerator & Freezer Repair)
by Guest 5/10/2022 4:59:08 AM(UTC)
Compressor fan will not stay running (Refrigerator & Freezer Repair)
by jesus freak 4/13/2022 3:25:46 PM(UTC)
Equivalent compressor (Refrigerator & Freezer Repair)
by Guest 2/10/2022 1:52:23 PM(UTC)
GE side by side clicks once by compressor then once on board. (Refrigerator & Freezer Repair)
by Schaanman 1/23/2022 2:03:33 AM(UTC)
GE Monogram Compressor Replacement (Refrigerator & Freezer Repair)
by utfandg 12/23/2021 1:49:44 PM(UTC)
