Discuss
GE Refridge Nothing works but the light?
 in
Refrigerator & Freezer Repair
You donít have any voltage from that wire to the Line wire (there should be). That is the wire that
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » GE Refridge Nothing works but the light?
  #21 (permalink)
Old 07-31-2009, 04:41 PM
Senior Member
applianceman is on a distinguished road
Default
You donít have any voltage from that wire to the Line wire (there should be). That is the wire that feeds the board natural. You need to look for places that this wire may be broken.
  #22 (permalink)
Old 07-31-2009, 05:09 PM
Senior Member
Default
Do you get a voltage reading if you place one lead on line and one to ground (the green wire)?
  #23 (permalink)
Old 08-01-2009, 06:55 AM
Junior Member
ant00r1 is on a distinguished road
Question
just checked it, no power from line to ground. just wondering, but what is the likelihood my fridge being wired different? all the instructions & everything i've read all applies to side X sides, where as mine is a top freezer. just wondering? ant
  #24 (permalink)
Old 08-01-2009, 07:28 AM
Senior Member
Default
The line side is broken that explains why you have voltage from the J7 pin 6 (it is open like reading across a open switch.
I have been looking at a service manual for your exact model. Also your board is the same board used on side-by-side models.
  #25 (permalink)
Old 08-01-2009, 11:10 AM
Junior Member
Lightbulb
ok, so by broken , do you mean the actual line plug is broken from the board or that the orange wire is broken before the board coming from lower part of fridge to the board? i assume that its the latter , because if i understand all this correctly there should be power on the orange wire not the purple? if you think thats where the problem is , i'm gonna start diggin in! ant
  #26 (permalink)
Old 08-01-2009, 11:43 AM
Senior Member
Default
No, the orange is neutral meaning you should have voltage from any line to neutral. Now that you say you donít have voltage when you check line to ground I think the line is open, which could be a plug loose or broken wire. Do you get voltage from the purple wire to the orange wire? From what I am hearing you will. Make sure all the plugs are connected. Then check to see if you have voltage from the purple wire to ground.
That purple wire is just a wire that lets the board know if the light in refrigerator is on or not. you get voltage to it because it connects to line but the board receives line from that wire marked line on the board.
  #27 (permalink)
Old 08-11-2009, 07:22 AM
Junior Member
Cool Fixed!!
it is with the greatest appreciation to all that helped me that i am even putting myself through the shame of posting this. to all of you that said " probably something unplugged or a broken wire" ,well sirs you were correct. turns out some dumba** (me) didn't plug the power wire to the board. i didn't pay attn when i was unplugging the plugs & didn't notice that the power plug didn't actually plug to a
"plug", just the actual terminals sticking up out of the board. i just thought that little purplish colored pug was for the dispenser models. so thats my confession. i really reall really appreciate everyones help! thanks again, ant
  #28 (permalink)
Old 08-11-2009, 09:45 AM
Senior Member
Default
Donít feel bad we all have done things like that even if we wonít admit it.
I saw the plug off in the picture but though you had it off to test sorry I didnít say anything. Anyways I am glad you figured it out!!
GE Refrigerator Repair Guide
  #29 (permalink)
Old 08-12-2009, 07:16 AM
Junior Member
Default one more easy one (hopefully)
can anyone tell me what regulates the temp/air flow to the fresh food section? i've looked at the drawings & the best i can tell is that there is no damper or diffuser. if that is the case what is it that the temp controls actually do? the problem is that the freezer is freezing but the fridge only gets down to 45 - 50 degrees. i pulled the panel out of the freezer & checked the evaporator. no ice just normal frost. i put a cup of water in the freezer & a cup of water with a thermometer in it in the fridge. the cup in the freezer froze. this is after the fridge had been running over 24 hrs. also the freezer setting was on 7 and the fridge was on 8. thanks once again! ant
  #30 (permalink)
Old 08-12-2009, 02:54 PM
Senior Member
Default
You might try turning the freezer control down a little this will allow more air into the refrigerator section.
Also make sure the fan is running and the doors are sealing good.
There is a possibility the fan blade is pushed onto the fan shaft too far which can cause an airflow problem. The back of the blade should be about an inch from the fan motor, which should leave ľ- 3/8 of an inch sticking out of the shroud.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Gas works, but does not light rwgiaimo Oven Repair (including Ranges and Cooktops) 1 08-01-2009 10:03 AM
oven won't light , pilot works Holiday Oven Repair (including Ranges and Cooktops) 1 06-12-2009 07:46 PM
Vent fan works but not light island girl Microwave Repair 1 02-05-2009 09:28 AM
Door light comes on and nothing works..... FDAR Dishwasher Repair 1 11-08-2008 05:14 AM
Regridgerator works, light doesn't Boomcoach Refrigerator & Freezer Repair 0 07-29-2008 10:02 AM
