Discuss
GE Refridge Nothing works but the light?
 in
Refrigerator & Freezer Repair
It is the orange wire on the bottom white plug. The first you see going from left to right.
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » GE Refridge Nothing works but the light?
  #11 (permalink)
Old 07-29-2009, 03:20 PM
Senior Member
applianceman is on a distinguished road
Default
  #12 (permalink)
Old 07-29-2009, 03:35 PM
Senior Member
Default
Try this only if you get 120V from L to N (orange wire).
You may have already done this if so let me know because I am not sure.
You should see a plug marked J2 unplug it. Check for voltage between pins 3 and 8 on the board. If you get 12VDC there may be a short in the fan circuit. Post what you find.
  #13 (permalink)
Old 07-29-2009, 03:39 PM
Junior Member
Randy9135 is on a distinguished road
Default Randy9135
Check the defrost timer.
  #14 (permalink)
Old 07-30-2009, 05:35 AM
Junior Member
ant00r1 is on a distinguished road
Lightbulb update
ok, not sure but my board may be laid out differently or something? i got 120v to purple wire on J7 plug from LINE . i checked every wire going to board & thats the only one that had anything. checked voltage between pins 3 & 8 on J2 , no voltage there. makin any sense yet? i'm lost. thanks again, ant
  #15 (permalink)
Old 07-30-2009, 06:12 AM
Senior Expert
APP Volunteer
richappy is a splendid one to behold
Default
Check your thermistors on Ji connector, upper right. Check them per my article in sticky above "GsS and HSS refrigerators". You might have a thermistor disconnected, that would shut the fridg. down.
__________________
  #16 (permalink)
Old 07-31-2009, 06:11 AM
Junior Member
Exclamation another update
hi again. richappy, i checked the thermistor pins as you described. they all seemed to check out right, i think. (3.8ohms with meter on 20K ohm setting) but pins 5 & 7 are a dead short , as they should be, because the are spliced together. (2 blue wires). thats the reading i got from the J1 plug. i added a pic of the board & labeled the plugs. the board is actually mounted upside-down on the back of the fridge. maybe this will help with my confusion? thanks again, ant
  #17 (permalink)
Old 07-31-2009, 06:41 AM
Senior Expert
APP Volunteer
Default
They have had a lot of problems with the power relay that powers the compressor and defrost. Even though new, you might want to check the solder connections on that relay, it's close to the 4 pin power connector, just follow the ribbons. Every time I have a problem with the board, I have to re-solder these relays.
Also, re-check carefully the thermistors per the temperature/resistance chart, you just might have a problem there.
__________________
  #18 (permalink)
Old 07-31-2009, 07:31 AM
Junior Member
Default my washer
thanks for the other info right now everything is ok but my main concern is my washer i realy need an answer if you can thanks.
  #19 (permalink)
Old 07-31-2009, 08:59 AM
Senior Member
Default
On the J7 plug the #9 pin (orange wire) is neutral (common) the pin all the way to the left looking straight at the board. You should have 120V from Line to that wire on the plug. If not I believe that is your problem you need to find out why you don’t have the neutral to the board. You may have a loose or broken wire. I know you said you have voltage to the purple wire what pin was that? Refrigerator repair guide
  #20 (permalink)
Old 07-31-2009, 04:16 PM
Junior Member
Default
applianceman, not sure if you saw it but if you look @ the pic above, the purple wire is pin #6 on J7 plug. the orange wire didn't have voltage going to it. ant
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Gas works, but does not light rwgiaimo Oven Repair (including Ranges and Cooktops) 1 08-01-2009 10:03 AM
oven won't light , pilot works Holiday Oven Repair (including Ranges and Cooktops) 1 06-12-2009 07:46 PM
Vent fan works but not light island girl Microwave Repair 1 02-05-2009 09:28 AM
Door light comes on and nothing works..... FDAR Dishwasher Repair 1 11-08-2008 05:14 AM
Regridgerator works, light doesn't Boomcoach Refrigerator & Freezer Repair 0 07-29-2008 10:02 AM
