Freezer stays very cold, fan blows cold and with force. Refrigerator section temp hovers from 45 to 55 degrees. Very little or no cold air is coming through the ports in the cabinet. My first thought is "iced up". Not defrosting. R & R defrost timer? If so, where is it? It's not in the lower rear where the comp. is and it's not in the lower front. Thanks in advance for any help!!!!
