Ice and water dispenser do not work. All lights on the front outside of the freezer above these are with out power. Ice maker and controls inside the fridge are fine and working. Do I have to remove this panel around the dispensers to find the issue? If so how do I remove it without damage? Also, the switch inside the freezer which is suppose to give power to these when the freezer door is closed is working.
