The ice maker is not making ice. The water valve is sending water to the door but none to the icemaker. I have checked the electrical current on the valve and it is getting juice BUT is not sending a message to the solenoid to pump the water to the icemaker. What could be the problem? Thank you in advance for your assistance.
The water line to the ice maker could be frozen or the water inlet valve is at fault and needs to be replaced.
