Hello,need Help W/ Ice Maker Not Working. Just Ordered Control And Motor Assembly For It ,but Have Blinking Light On Switch Board??,Goes to steady red light when push lever door in. Just had to order filter housing unit due to plastic spacer broke for 5/16'' tube holding tight,sprayed water and drained into pan a lot,should this be sign that water inlet is ok and wait to re hook up?
