Discuss
Kenmore Top Mount Refrigerator
 in
Refrigerator & Freezer Repair
Our Kenmore Refrigerator is leaking water from the Cold Control Defrost Timer/Automatic Defrost Control Housing. I have adjusted the
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Kenmore Top Mount Refrigerator
  #1 (permalink)
Old 01-04-2008, 08:21 PM
Christopher14 Christopher14 is offline
Junior Member
Christopher14 is on a distinguished road
Default Kenmore Top Mount Refrigerator
Model Number: 253 or 970   Brand: Kenmore   Age: 1 - 5 years
Our Kenmore Refrigerator is leaking water from the Cold Control Defrost Timer/Automatic Defrost Control Housing. I have adjusted the temperature in both the freezer and fridge but it is still occurring. Any suggestions?
Chris
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 01-05-2008, 05:47 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
Pull freezer back panel. You will find the drain frozen. I use a turkey baster and hot water to fix this, I also wrap a heavy gauge wire around the defrost heater and down the drain to fix this.
__________________
  #3 (permalink)
Old 01-06-2008, 09:32 PM
Junior Member
Default
We have pulled the panel off and the drain was not frozen. Thanks for the suggestion.
Christopher
  #4 (permalink)
Old 04-18-2008, 10:10 AM
zelda zelda is offline
Junior Member
zelda is on a distinguished road
Default
Quote:
"Our Kenmore Refrigerator is leaking water from the Cold Control Defrost Timer/Automatic Defrost Control Housing."
I have been having this same problem with our 6 year old Kenmore Top Mount. I have had repairmen out twice. Both times there was a solid layer of ice in the defrost drain pan. Both times they pour hot water down the drain line (?) to clear it out - apparently something had gotten in and clogged it?? This time around I shut the refrigerator off and defrosted it. I took off the back panel inside the freezer and found the drain hole. The last repairman left a piece of aluminum wire in the drain hole - to prevent future clogs, I think. Anyway, why does the drain hole keep freezing up?? The last occurence was just about a year ago.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore Refrigerator Freezer Side By Side mchwalowski Refrigerator & Freezer Repair 1 11-28-2007 10:49 PM
top-mount refrigerator jack roberts Refrigerator & Freezer Repair 1 10-29-2007 05:30 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
