| » suspect bored problem |
Model Number: gb2026pekb Brand: Amana Age: 1 - 5 years
hi i have this amana f/freezer with large pull out freezer draw on bottom the problem i suspect wnich is the bored ,i would like it confimed .with the door closed the compessor and condensor fan wont run if i open the door the compressor and fan run if i press light swith in compressor and fan stop i would be gratful for a answer
Quote:
hi thanks for a quick reply what you said sounds about right ive done refigeration in england for about 40 years but we just starting to get alotof these amanas and maytags coming through so getting parts have been a bit of a problem now ive found appliance parts it should not be a problem ive heared somwhere when you fit thisnew bored you have to reset the code is that correct |
Yes, per the jnstuctions you have to put in the code. Don't do what I did, you must push in the numbers till the display blinks, like a few seconds, other wise it's not entered.
__________________
Quote:
speak with you again, will let you know the outcome regards saints |
| Display Modes | |
| Suspect Timer problem | rockinga | Dryer Repair | 5 | 07-22-2010 01:37 AM |
