Pulled voltage off the heating element wire and got a 6.2 for the freezer. What is causing the lack of power to heat the element?
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
Originally Posted by: TnD Please click one of the Quick Reply icons in the posts above to activate Quick Reply. Pulled 6.2 volts off the freezer heating element wires. What could cause the voltage to be so low?
