Discuss
Wire configuration for relay/ovrload switch
 in
Refrigerator & Freezer Repair
I just bought a relay/overload switch with no diagram of the appropriate wire configuration. I have one white, one
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Wire configuration for relay/ovrload switch
  #1 (permalink)
Old 01-04-2008, 04:35 PM
Brian Olsen Brian Olsen is offline
Junior Member
Brian Olsen is on a distinguished road
Default Wire configuration for relay/ovrload switch
Model Number: ptb2154grw   Brand: Maytag   Age: 1 - 5 years
I just bought a relay/overload switch with no diagram of the appropriate wire configuration. I have one white, one orange and one blue wire. Can someone please tell me where to install each wire in this relay/overload switch so I don't blow up my frige? part number is ap3502227 for a Maytag refrigerator model # ptb2154grw thanks.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 01-05-2008, 03:58 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
They sent you the wrong control!! part AP3502227 is a direct plug in exactly like your old one. If your new part has wires that plug in, it will not give you compressor thermal protection!
__________________
  #3 (permalink)
Old 01-05-2008, 07:00 AM
Junior Member
Default
This is the right part....the old switch was from Texas instruments. The new part has the same plug arrangement when plugged to condensor. However the receptacles in which the wires need to be attached are in a different arrangement and there are no directions/schematics to which I can refer to to get the right plug in configuration. I may be calling this part by the wrong name but this is the part I need and do have.
  #4 (permalink)
Old 01-06-2008, 03:28 AM
Senior Expert
APP Volunteer
Default
Send us a picture if you can.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Relay verses Switch Control Panel Boater Oven Repair (including Ranges and Cooktops) 2 03-05-2008 09:34 AM
Relay switch wont engage automaticaly to turn ac on per thermostat lolo Heating, Ventilation, and Air Conditioning (HVAC) 3 01-16-2008 06:56 PM
Infinite Wire Switch Dual Element leighr3 Oven Repair (including Ranges and Cooktops) 1 12-11-2007 02:04 PM
infinite switch wiring change from 6 wires to 5 wire switch wiedemanndds Oven Repair (including Ranges and Cooktops) 3 12-06-2007 01:45 PM
short in wire dwstevens Dryer Repair 1 10-29-2007 04:11 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
