We got this fridge from someone and when u plug it up it comes on but isnt cooling fridge or freezer at all.. Seems to b no air flow can u plezz help me?? the fan n compressor seem to b working..
Is the freezer fan working?
The fan works. It just blows out warm air. The freezer and refer doesnt get cold at all.
Pull the start device off the side of the compressor if the compressor is warm but not vibrating AP4298809.
It vibrates n the compressor is running..
If the compressor is warm and the condenser coils warm, you have refrigeration problems, probably not worth fixing.
Do u think it might need charging or freon.
Almost all the newer R134A refrigerant refrigerators have fragile compressors and most leaks are so bad the compressor sucks in a non-compressable air that damages the compressor. Pressure gauges would confirm.
