Old Wino
#1 Posted : Thursday, January 19, 2012 7:52:56 AM(UTC)
Old Wino
Refrigerator is currently around 32 degrees, even tho setting is at lowest (sun icon). Freezer is below zero, and is also set at lowest) . The freezer was accidentally turned off for part of a day last week. I also did clean the very dirty coils yesterday and also the back grate. What else should I try?
#2 Posted : Friday, January 20, 2012 4:44:52 AM(UTC)
Replacement parts for Amana TR18V2E REF - TOP MOUNT | AppliancePartsPros.com
Is the compressor cycling normally or is it on all the time?
Measure the freezer temperature. It should be between 0 and -5 degrees F.
If lower then your main thermostat (Item 62 in Section 5) probably needs replacing.
if the freezer temperature is OK then check the damper (Item 42 in Section 5), to see if it opens/closes depending on it's setting.
Check that the door can open/close, could be that due to the unit being turned off some water got into it and froze the door open.
Unfortunately it is obsolete.
Old Wino
#3 Posted : Friday, January 20, 2012 8:45:26 AM(UTC)
Old Wino
Originally Posted by: denman Go to Quoted Post
No, door opens, closes oK. Seems to me freezer was running closer to ten below. A local outfit said something about setting the freezer colder so less cold gets circulated to fridge. Been less than 24 hours, but seemed to have no effect. He thought baffle might need replacing. Does that sound right?
#4 Posted : Friday, January 20, 2012 9:25:50 AM(UTC)
I would get the freezer to the recommended temperature and then see what happens.
The 24 hours makes sense to me as the food/ice in the freezer will take quite a while to come up to temperature.
Lowering the temperature does not make sense as it will cause the compressor to run more and I believe your evaporator fan runs whenever the compressor runs so there is more air circulation.
Note:I may be out to lunch on this.
I do not know if I screwed up but I meant the door/flapper on the damper assembly.
It should close on the warmest fresh food setting.
Top freezer refrigerator too cold. (Refrigerator & Freezer Repair)
by yaworski 2/15/2021 10:38:29 AM(UTC)
Samsung Refrigerator too cold (Refrigerator & Freezer Repair)
by jim.grove1 1/30/2020 10:26:16 AM(UTC)
Kitchen Aid Refrigerator Too Cold (Refrigerator & Freezer Repair)
by txh123 10/26/2016 5:27:11 PM(UTC)
Frigidaire S x S refrigerator too cold (Refrigerator & Freezer Repair)
by APPLIANCEDUDE1972 12/11/2014 6:27:01 PM(UTC)
GE refrigerator too cold, unstable temp cycle (Refrigerator & Freezer Repair)
by James2000 5/23/2014 8:15:56 AM(UTC)
Kenmore side by side refrigerator too cold (Refrigerator & Freezer Repair)
by Fisheyeii 11/16/2013 5:36:27 AM(UTC)
Refrigerator too cold, Freezer melting and refreezing (Refrigerator & Freezer Repair)
by ejnelson24 2/20/2013 3:48:45 PM(UTC)
KitchenAid Refrigerator Too Cold (Refrigerator & Freezer Repair)
by famcar 12/21/2012 5:41:32 PM(UTC)
Refrigerator too cold and uncontrolable (Refrigerator & Freezer Repair)
by nailerdog 3/25/2012 7:57:15 AM(UTC)
Refrigerator Too Cold Vegetables Freezing (Refrigerator & Freezer Repair)
by olgapico 11/15/2011 7:43:20 AM(UTC)
by lgray215 10/12/2011 4:08:57 PM(UTC)
by jimmybass 9/16/2011 12:41:24 PM(UTC)
by TaniaH 4/1/2011 7:52:26 AM(UTC)
by Paul Sobus 3/9/2011 6:22:01 AM(UTC)
Refrigerator too cold (Dishwasher Repair)
by DEEDEEGOGO 2/21/2011 4:15:39 PM(UTC)
