Discuss
compressor hard start
 in
Refrigerator & Freezer Repair
amana refrigerator model ARS2663AW (PARS2663AWD). replaced combo relay/overload device part number AP4369220 still having intermident hard start, works on second
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » compressor hard start
  #1 (permalink)
Old 01-18-2012, 12:50 PM
Junior Member
jakelaker is on a distinguished road
Default compressor hard start
Model Number: ARS2663AW   Brand: Amana   Age: More than 10 years
amana refrigerator model ARS2663AW (PARS2663AWD). replaced combo relay/overload device part number AP4369220 still having intermident hard start, works on second attempt. is it possible to add capacitor part number AP4074064 to combo start device for greater starting torque. or is there a 3/1 hard start device, such as part number AP4503415 that might be a better attempt at a solution. compressor when running runs cool, do not belive it is overheating. parts box for combo had W10189190 on box. Thanks!!
Related Models
Amana ARS2663AW REF - SXS/I&W
Amana ARS2664AB REF - SXS/I&W
Amana ARS2664AC REF - SXS/I&W
Amana ARS2664AW REF - SXS/I&W
Amana ARS2664BB REF - SXS/I&W
Amana ARS2664BC REF - SXS/I&W
Amana ARS2664BS REF - SXS/I&W
Amana ARS2664BW REF - SXS/I&W
Amana ARS2665AB REF - SXS/I&W
Amana ARS2665AC REF - SXS/I&W
Amana ARS2665AW REF - SXS/I&W
Amana ARS2666AB REF - SXS/I&W
Amana ARS2666AC REF - SXS/I&W
Amana ARS2666AW REF - SXS/I&W
Amana ARS2667AB REF - SXS/I&W
Amana ARS2667AC REF - SXS/I&W
Amana ARS2667AS REF - SXS/I&W
Amana ARS2667AW REF - SXS/I&W
Amana ARS2667BB REF - SXS/I&W
Amana ARS2667BC REF - SXS/I&W
Amana ARS2667BS REF - SXS/I&W
Amana ARS2667BW REF - SXS/I&W
Amana ARS266KBB REF - SXS/I&W
Amana ARS266KBC REF - SXS/I&W
Amana ARS266KBW REF - SXS/I&W
Amana ARS266RBB REF - SXS/I&W
Amana ARS266RBC REF - SXS/I&W
Amana ARS266RBW REF - SXS/I&W
Amana ARS266XAW REF - SXS/I&W
Amana ARS266ZBB REF - SXS/I&W
Amana ARS266ZBC REF - SXS/I&W
Amana ARS266ZBS REF - SXS/I&W
Amana ARS266ZBW REF - SXS/I&W
Amana ARS2760BW REF - SXS/I&W
Amana ARS635 RANGE- S/C S/I DDRAFT ELE
Amana ARS635W RANGE- S/C S/I DDRAFT ELE
Amana ARS635W RANGE- S/C S/I ELE
Amana ARS636E RANGE- S/C S/I ELE
Amana ARS636WW RANGE- S/C S/I ELE
Amana ARS8265BB REF - SXS/I&W
Amana ARS8265BC REF - SXS/I&W
Amana ARS8265BS REF - SXS/I&W
Amana ARS8265BW REF - SXS/I&W
Amana ARS8267BB REF - SXS/I&W
Amana ARS8267BC REF - SXS/I&W
Amana ARS8267BS REF - SXS/I&W
Amana ARS8267BW REF - SXS/I&W
Amana ARS9107AS REF - SXS/I&W
Amana ARS9107AW REF - SXS/I&W
Amana ARS9167AB REF - SXS/I&W
Amana ARS9167AC REF - SXS/I&W
Amana ARS9167AS REF - SXS/I&W
Amana ARS9167AW REF - SXS/I&W
Amana ARS9168AB REF - SXS/I&W
Amana ARS9168AC REF - SXS/I&W
Amana ARS9168AS REF - SXS/I&W
Amana ARS9168AW REF - SXS/I&W
Amana ARS9169AS REF - SXS/I&W
Amana ARS9265BB REF - SXS/I&W
Amana ARS9265BC REF - SXS/I&W
Amana ARS9265BW REF - SXS/I&W
Amana ARS9266BS REF - SXS/I&W
Amana ARS9268BB REF - SXS/I&W
Amana ARS9268BC REF - SXS/I&W
Amana ARS9268BW REF - SXS/I&W
Amana ARS9269BS REF - SXS/I&W
Amana ARSE664BB REF - SXS/I&W
Amana ARSE664BC REF - SXS/I&W
Amana ARSE664BS REF - SXS/I&W
Amana ARSE664BW REF - SXS/I&W
Amana ARSE665BB REF - SXS/I&W
Amana ARSE665BC REF - SXS/I&W
Amana ARSE665BS REF - SXS/I&W
Amana ARSE665BW REF - SXS/I&W
Amana ARSE667BB REF - SXS/I&W
Amana ARSE667BC REF - SXS/I&W
Amana ARSE667BS REF - SXS/I&W
Amana ARSE667BW REF - SXS/I&W
Amana ARSE66MBB REF - SXS/I&W
Amana ARSE66MBC REF - SXS/I&W
Amana ARSE66MBW REF - SXS/I&W
Amana ARSE66ZBB REF - SXS/I&W
Amana ARSE66ZBC REF - SXS/I&W
Amana ARSE66ZBS REF - SXS/I&W
Amana ARSE66ZBW REF - SXS/I&W
Amana ARSE67RBB REF - SXS/I&W
Amana ARSE67RBC REF - SXS/I&W
Amana ARSE67RBS REF - SXS/I&W
Amana ARSE67RBW REF - SXS/I&W
Amana ART1805BC REF - TOP MOUNT
Amana ART1805BW REF - TOP MOUNT
  #2 (permalink)
Old 01-19-2012, 02:31 AM
Senior Expert
APP Volunteer
richappy is a splendid one to behold
Default
Measure the freezer temperature and post, the compressor should be warm, and the condensing coils warm if compressor is running.
You have an R134A compressor in this that will eventually burn out if you use the 3 n 1 hard start device.
__________________
  #3 (permalink)
Old 01-19-2012, 06:55 AM
Junior Member
Default hard start compressor
the frezer temperature is 12 deg. with temperature control set at 4. the refrigator temperature at mid. height is 34 deg. with temperature control set between 4 and 5. the evaporator coil fan is running, when compressor is running. the compressor runs warm. is capacitor part number AP4074064 pluged into combo start device (thin slots unlabled) a possibleity. Thanks!!!
  #4 (permalink)
Old 01-19-2012, 09:19 AM
Senior Expert
APP Volunteer
Default
Yes the run capacitor plugs into the narrow slots in the start device. You might have a bad cold control in this. Set the cold control to the lowest temperature setting and after a period of time, measure the freezer temperature, should be below zero and the fridg should run all the time.
__________________
  #5 (permalink)
Old 01-19-2012, 01:01 PM
Junior Member
daughter called back and stated that frezzer temperature was at 0 degrees when she checked after one hour.. first time we waited only about ten minutes to take reading. would like to try to add a capacitor on combo start device. wiring diagram shows start capacitor used on some refiigerators, but this refigerator did not have one, (no gray wire). Thanks!!!
  #6 (permalink)
Old 01-19-2012, 01:35 PM
Senior Expert
APP Volunteer
Default
No modern refrigerator uses a start capacitor, most use a run capacitor.
If you are still having starting problems, only safe fix for this is using a start ptc device with a lower resistance. Using a start capacitor will lead to eventual compressor failure. The new R134A compressors will burn out due to the uncontrolled, high inrush current they provide.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kiithen Aid dishwasher hard to start pssf14 Dishwasher Repair 0 05-27-2011 07:15 AM
Maytag hard start defineran Dryer Repair 1 09-07-2008 11:33 AM
Compressor has a hard time to get started guidokury Refrigerator & Freezer Repair 1 01-07-2008 07:26 PM
Installed Hard start kit on refrig Jim Stapleton Refrigerator & Freezer Repair 0 11-28-2007 10:18 AM
