| » coldspot not cooling, fan working, clicking relay |
Model Number: 105.58587892 Brand: Kenmore Age: More than 10 years
My Kenmore Coldspot side by side refrigerator is no longer cooling. Manufacture date 1999. The light is on and the fan running. Here is what happens when i turn it on :- - the fan starts and runs ok - after a few seconds I hear a click from the relay - the condenser body starts to get warm - over the course of 3 minutes the relay clicks 3-4 more times. On each click the tone of the fan changed slightly. Leading up this failure, over the past month we have had to adjust the setting on the fridge because it did not seem to get cold enough. Then it would too cold and we'd adjust it back down. That happened a few times over the past month. Reading the forum it seems it could be the relay, but I don't know what part to get and the part number of 105.58587892 seems to come up with microwaves and a range. Thanks for any help with troubleshooting. Ads By Google Related Models |
Try to replace the start device for the compressor.
- The start device Part number: AP3083556 Gene. P.S. The correct model number has 106 prefix.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
Gene,
Thank you so much for the help and the link to the part. I removed the what i think are the relay parts from the fridge and found that the brown relay (shown in photos below) rattles and small clay like particles are falling out of it. Does that mean it is blown or bust. You can also see the serial numbers of the parts. Can you confirm that the AP3083556 part number is the correct one? http://i1240.photobucket.com/albums/...t_relays_2.jpg http://i1240.photobucket.com/albums/...pot_relays.jpg relay_serial_nums.jpg picture by mcontact - Photobucket Thanks mike |
Mike,
I did not get clear why I have to confirm the part number I posted? It came up according to the model number you posted. Gene.
__________________
Quote:
I was just posting the photos to make sure it was the right part. Sorry. Being too thorough. Thank you for the help. Do appreciate your expert help. mike |
No problem Mike. Keep us posted.
__________________
Hi Gene,
I ordered up the restart kit on Wed, received Fri and installed on the weekend just past. It worked first time. The fridge is up and running great! Thank you so much, you have saved us a small fortune. While I was cleaning the parts on the bottom of the fridge I noticed a water leak coming from the inside end of of the filter housing. Its where some long plastic pipes, two of them, enter the back of the housing. There are two little plastic grommets around each tube and these then seat within the housing. I didn't take it apart because the water filter would not come out. Now the part is back on the fridge frame I can remove the filter. I was wondering, is there a fix for this leak, maybe new grommets or will it require a new filter housing. thanks mike |
You are welcome Mike. I'm glad you were able to fix this problem.
Regarding the water leak - it has to be fixed ASAP. A small leak always turns into a larger. Looks like you have to replace the filter housing. Use a sharp knife to cut off the tubes connected to the old housing. Just push then into the new housing fittings. Do not forget to shut off the water to the refrigerator. - The filter housing Part number: AP3085317 Gene.
__________________
| Display Modes | |
| Replacing Relay on Coldspot Refrigerator | Allen Scott | Refrigerator & Freezer Repair | 4 | 01-04-2012 01:59 AM |
| kemore coldspot not cooling | lcook80 | Refrigerator & Freezer Repair | 1 | 08-01-2011 02:37 PM |
| Kenmore Coldspot Compressor relay clicking | Scott SS115 | Refrigerator & Freezer Repair | 1 | 05-27-2011 08:04 AM |
| Clicking Noise on Coldspot Freezer | bduff@nof.com | Refrigerator & Freezer Repair | 1 | 10-20-2010 11:31 AM |
| clicking from relay | meckinator | Refrigerator & Freezer Repair | 1 | 12-16-2008 04:05 PM |
