unit is 18 months old. No cold air. Freezer coil and rear coil are clean. Rear coil at room temp.Ohmed out comp, read 12 ohms and 6 ohms, Nothing shorted to ground. When running, pulling .9 amps, compressor gets worm but coil stays at room temp. Need advice!!
