My fridge door will not stay clean. I continously scrub off these brown looking stains off the front fridge door (see pic) only to have them reapprear. A very aggravating problem. Can anyone please help? Thanks, Handy Dan handydandy1958 attached the following image(s):
Is there a smoker in the house?
Looks like there is residue left on the door and kitchen grease or smoke is condensing onto it.
Try cleaning it with isopropyl alcohol. If that does nothing, then I would try varsol. Try it in an inconspicuous place first just to be sure it will not damage the finish. Also do not use it on plastic/rubber.
Once good and clean give it a coat or two of car wax.
I would check to see if the door face is cold. Could be the insulation has gotten wet over the years and is not doing a very good job anymore and that is causing excessive condensation. |
THIS FORUM IS DEAD!!!!!!! |
