Discuss
Which ice maker water valve to order?
 in
Refrigerator & Freezer Repair
My ice maker is not filling with any water. I hear the "buzzing" coming from the lower cabinet
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Which ice maker water valve to order?
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 01-03-2008, 11:02 AM
blazindaily blazindaily is offline
Junior Member
blazindaily is on a distinguished road
Question Which ice maker water valve to order?
Model Number: FRS22ZRFW2   Brand: Frigidaire   Age: 5 - 10 years
My ice maker is not filling with any water. I hear the "buzzing" coming from the lower cabinet which tells me the coil is getting current but the valve must be stuck and is not opening to supply the water to the ice maker.
I've removed the cardboard cover at the back, exposing the compressor and associated equipment. I can see two sets of two valves; one set is on the right where the large water supply hose comes in. I also see another set of two valves on the left hand side at the back of the fridge.
Which set of valves do I replace or do I replace both sets?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 01-03-2008, 02:38 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Before replacing any parts I would recommend to check the water feeding tube coming into the ice maker. It could be frozen up. You can defrost it using a hair dryer.
- The part number for the ice maker water valve is AP2114949
- Here are the break down diagrams for the Frigidaire refrigerator Model FRS22ZRFW2
Good luck.
__________________
Professional appliance repair services in Orange County, California.
  #3 (permalink)
Old 01-15-2008, 07:45 PM
JAFO JAFO is offline
Junior Member
JAFO is on a distinguished road
Default
Mine is doing tihe same thing, I checked the feed valve (green, yellow) it had very low pressure comming out of it. Good pressure at supply. What would happen if i bypassed this valve? and supplied good pressure at the secound valve? Why have two valves that feed the same line?
Let me know if you find any thing, I'm going to work on mine tommorw again.
JT
  #4 (permalink)
Old 01-15-2008, 07:52 PM
Junior Member
Default
JT
JAFO, I replaced the valve unit (looks like two valves) with a new one. part number was as above stated by Gene: AP2114949. My ice maker is now working just fine. I did not take the old assembly apart, but I suspect it was caked up with solids from 10 years of use. Hope this helps.
  #5 (permalink)
Old 01-15-2008, 09:13 PM
bugsdoc1 bugsdoc1 is offline
Junior Member
bugsdoc1 is on a distinguished road
Question ICE Maker
Replaced water valve obtained fro Sears Parts Central. Was A Fridgidaire Part for a Kenmore 25357685790 Side by Side.
Water Dispenser is now working GREAT
Still NO ice production
I have used a hair drier to the supply hose
What else do you Pro's reccommend!
  #6 (permalink)
Old 01-16-2008, 02:06 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
Check the fill tube in the freezer, probably iced up. If so, your freezer temperature might be too cold.
__________________
  #7 (permalink)
Old 01-16-2008, 06:16 AM
catfishonly catfishonly is offline
Junior Member
catfishonly is on a distinguished road
Default
i had the same problem and mine was frooze i used a hair dryer to thaw if it is a side by side the hose runs threw the refridge and i thawed mine in there
  #8 (permalink)
Old 01-16-2008, 06:19 AM
kawfeeman kawfeeman is offline
Senior Expert
APP Volunteer
kawfeeman is on a distinguished road
Default
do you have the serial # ?
__________________
regards
jim
  #9 (permalink)
Old 01-16-2008, 11:31 AM
Junior Member
Smile
Kenmore Model # 25357685790
Build date: 07-97
Serial Number: LA72807052
Thanks for all the feedback and help!
Do I need valve # AP2114865
also?
My Water tubes are on the back of the unit.
  #10 (permalink)
Old 01-17-2008, 10:29 AM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi bugsdoc1,
If you already replaced the following water valve
and you are sure the water feeding tube
is clear and the water filter is fresh, then the second water valve
has to be replaced.
- The part number for the water valve is AP2114865
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
replacing outlet valve for ice maker stanleyn Refrigerator & Freezer Repair 1 12-17-2007 07:02 PM
Ice Maker water valve Jaye Refrigerator & Freezer Repair 1 12-11-2007 05:26 PM
Maytag has new water valve, but no water ultimatefighter34 Dishwasher Repair 3 11-02-2007 12:02 PM
Ice maker still leaking - Just replaced fill valve Adam80 Refrigerator & Freezer Repair 1 09-12-2007 07:09 PM
Water inlet valve gentleben Refrigerator & Freezer Repair 1 07-19-2007 11:04 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
