My ice maker works. When I push the lever on the door to dispense the ice it makes no noise and dispenses no ice even though the door does open. I have emptied the ice maker and found no ice jam. The water dispenser does work.
Does this model have a computer card that needs replaced or is there another problem that I can fix without calling a repairman.
Quote:that only a technician can replace or test. I would have to disagree with the only a technician can replace or test part. Quote:Your best bet is to contact Frigidaire and see if they have any troubleshooting over the phone first, before you pay for a tech. Frigidaire will not give you any technical support over the phone.
