Discuss
Compressor won't run - light is on
 in
Refrigerator & Freezer Repair
Hi. I am hoping you can guide me through troubleshooting my problem. The refrigerator just suddenly stopped running - the light
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Compressor won't run - light is on
  #1 (permalink)
Old 01-03-2008, 11:25 AM
skjohnstone skjohnstone is offline
Junior Member
skjohnstone is on a distinguished road
Default Compressor won't run - light is on
Model Number: ED25DQXAW01   Brand: Whirlpool   Age: More than 10 years
Hi. I am hoping you can guide me through troubleshooting my problem. The refrigerator just suddenly stopped running - the light comes on. I have an old repair manual that first directs me to test the defrost timer. I opened the control panel on the inside front top. There is a circuit board-looking defrost timer up there that looks nothing like the defrost timer in the manual. Can this be tested? Is this the best starting point (most likely cause of the problem)? Can you help? Thanks.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 01-03-2008, 05:08 PM
misterfixall misterfixall is offline
Senior Expert
APP Volunteer
misterfixall is on a distinguished road
Default
do you hear any clicking noise coming from relay on compressor every 30 sconds or so/ other than that i would acess cold control thermostat +jump wires +see what happens
__________________
  #3 (permalink)
Old 01-03-2008, 06:21 PM
Junior Member
Default
Thank you for your reply. No clicking from compressor/relay area. I tried jumping the cold control thermostat and it didn't crank up the compressor. I also tried to jump the capacitor and that didn't do anything. I used an ammeter over the compressor contact pins, and in the holes on the relay that plug onto these pins, and the ammeter needle confirmed continuity where expected. I'm pretty strongly suspecting the defrost timer circuit board. Is there a way to jump this to confirm that it's the problem, or I do just order the $62 part on faith that the other culprits are ruled out. I appreciate your help.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
compressor not working zjiqi0 Refrigerator & Freezer Repair 7 12-26-2007 03:31 PM
Compressor not running julimarie Refrigerator & Freezer Repair 3 12-25-2007 03:41 AM
intermittent compressor jdea Refrigerator & Freezer Repair 3 12-12-2007 07:59 AM
compressor won't shut off ripitup Refrigerator & Freezer Repair 7 12-04-2007 03:47 PM
Compressor installation rmdrc Refrigerator & Freezer Repair 1 10-31-2007 03:32 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
