Discuss
Refrigerator Inner Door Gasket Replacement - Hinges Bent?
 in
Refrigerator & Freezer Repair
I purchased part no. 12550115Q and have received it. I plan on replacing the existing gasket because it is pulling
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Refrigerator Inner Door Gasket Replacement - Hinges Bent?
  #1 (permalink)
Old 07-10-2009, 01:49 PM
Junior Member
RazorFish is on a distinguished road
Default Refrigerator Inner Door Gasket Replacement - Hinges Bent?
Model Number: BX22A2W   Brand: Amana   Age: More than 10 years
I purchased part no. 12550115Q and have received it. I plan on replacing the existing gasket because it is pulling out and away on the bottom right corner with a right hand hinge on the door - opens from left to right. I was reading online and someone mentioned a common cause of the gasket problem is a bent hinge. How would I determine whether I also had a hinge problem? The refrigerator door falls roughly 1/8" from the top right to top left side. Do I need to purchase another part or make an adjustment to hinge?
Ads By Google
Related Models
Amana BX22A2W Ref - Bottom Mounts
Amana BX22A5L Ref - Bottom Mounts
Amana BX22A5W Ref - Bottom Mounts
Amana BX22R3E Ref - Bottom Mounts
Amana BX22R3L Ref - Bottom Mounts
Amana BX22R3W Ref - Bottom Mounts
Amana BX22RE Ref - Bottom Mounts
Amana BX22RL Ref - Bottom Mounts
Amana BX22RW Ref - Bottom Mounts
Amana BX22S5E Ref - Bottom Mounts
Amana BX22S5L Ref - Bottom Mounts
Amana BX22S5W Ref - Bottom Mounts
Amana BX22TE Ref - Bottom Mounts
Amana BX22TL Ref - Bottom Mounts
Amana BX22TW Ref - Bottom Mounts
Amana BX518VE Ref - Bottom Mounts
Amana BX518VW Ref - Bottom Mounts
Amana BX521VCPER Ref - Bottom Mounts
Amana BX521VCPSR Ref - Bottom Mounts
Amana BX521VCPWR Ref - Bottom Mounts
Amana BX521VE Ref - Bottom Mounts
Amana BX521VW Ref - Bottom Mounts
Amana BXF19TL Ref - Bottom Mounts
Amana BXF19TW Ref - Bottom Mounts
Amana BXI21VE Ref - Bottom Mounts
Amana BXI21VL Ref - Bottom Mounts
Amana BXI21VW Ref - Bottom Mounts
Amana BXI22S5E Ref - Bottom Mounts
Amana BXI22S5L Ref - Bottom Mounts
Amana BXI22S5W Ref - Bottom Mounts
Whirlpool BYCCD3421W0
Whirlpool BYCCD3421W1
Whirlpool BYCCD3421W2
Whirlpool BYCCD3421W3
Whirlpool BYCCD3921W0
Whirlpool BYCD3722W0
Whirlpool BYCD3722W1
Whirlpool BYCD3723W0
Whirlpool BYCD3723W1
Whirlpool BYCD3723W2
Whirlpool BYCD4932W0
Whirlpool BYCD4933W0
Whirlpool BYCW4271W0
Whirlpool BYCW6292W0
Whirlpool BYCWD6274W0
Whirlpool BYCWD6274W1
Whirlpool BYCWD6274W2
Whirlpool BYCWD6274W3 Washer/dryer Laundry System
Whirlpool BYCWD6274W4 Washer/dryer Laundry System
Amana BZ20QE Ref - Bottom Mounts
Amana BZ20QG Ref - Bottom Mounts
Amana BZ20QL Ref - Bottom Mounts
Amana BZ20QW Ref - Bottom Mounts
Amana BZ20R Ref - Bottom Mounts
Amana BZ20RE Ref - Bottom Mounts
Amana BZ20RG Ref - Bottom Mounts
Amana BZ20RL Ref - Bottom Mounts
Amana BZ20RW Ref - Bottom Mounts
Amana BZ22QE Ref - Bottom Mounts
Amana BZ22QL Ref - Bottom Mounts
Amana BZ22QW Ref - Bottom Mounts
Amana BZ22R3E Ref - Bottom Mounts
Amana BZ22R3L Ref - Bottom Mounts
Amana BZ22R3W Ref - Bottom Mounts
Amana BZ22R5L Ref - Bottom Mounts
Amana BZ22R5W Ref - Bottom Mounts
Amana BZ22RE Ref - Bottom Mounts
Amana BZ22RL Ref - Bottom Mounts
Amana BZ22RW Ref - Bottom Mounts
Jenn-Air C Surface Unit - Ddraft Ele
Amana C-11 Freezer - Chest
Amana C-15 Freezer - Chest
Amana C-19 Freezer - Chest
Amana C-28 Freezer - Chest
Hardwick C-413 Surface Unit - Gas
Hardwick C-414 Surface Unit - Gas
Hardwick C-423 Surface Unit - Gas
Hardwick C-424 Surface Unit - Gas
Hardwick C-433 Surface Unit - Gas
Hardwick C-434 Surface Unit - Gas
Hardwick C-443 Surface Unit - Gas
Hardwick C-444 Surface Unit - Gas
Jenn-Air C100 Surface Unit - Ddraft Ele
Amana C100DW Freezer - Chest
Amana C100FW Freezer - Chest
Jenn-Air C101 Surface Unit - Ddraft Ele
  #2 (permalink)
Old 07-16-2009, 10:16 AM
Junior Member
Default
I've replaced the door gasket with success and thought I'd share my learning. This is an easy two-man job. Working alone is possible, but would have been a lot more work. I proceeded as follows:
- Start by placing the gasket in the dryer for about 5 minutes on low heat. This warms up the gasket, makes it pliable, and helps it to resume its original shape - not perfect shape, but better than how it was shipped.
- The inner door shell holds the gasket in place with this model so slightly loosen the existing screws and gently pull out the old gasket from under the shell. Do not remove the screws completely or you may have problems re-aligning the inner door shell.
- I began installing the new gasket at the top of the door. There is a lip on the gasket that needs to slide into a groove in the door shell. I loosened the screws a little further to create more room for inserting the gasket.
- When I had the top and the two sides inserted, I tightened the top and side screws about 3/4 way down the sides leaving enough play for the bottom still to flex.
- The corners were the hardest part to insert and get to lay flat correctly. I used a small screw driver to smooth the gasket around the corners. Be gentle not to damage the door or the gasket for this step.
- I now started working the bottom from one side to the other and tightened the screws as I worked across the bottom trailing with the tightening just enough to allow flex for insertion of the gasket.
- The last corner was the trickiest, but will smooth out assuming you are patient and keep gently working the gasket and inner door shell.
- It was very helpful to have a second person holding out the door shell while I inserted the gasket.
- Once the gasket was properly in place, I ensured all of the screws were tight and checked the seal on the door to the refrigerator.
- There were several locations where the gasket did not seal correctly to the refrigerator. Using a hair dryer, I was able to gently heat and work the gasket with my fingers to smooth out the remaining kinks in the gasket. This process took me about a 1/2 hour and the door now closes correctly and has a tight seal.
- Lastly, I loosened the top hinge on the top door and gently realigned the door to ensure the gap between the gasket and middle hinge hardware. It appears to be a poor design/flaw since the gasket still slightly contacts the middle hinge with the gasket completely smoothed out and the door aligned correctly with the top of the refrigerator. Since the first gasket lasted close to 15 years, I'm assuming I will replace the refrigerator prior to the new gasket failing.
- Good luck and be patient with the process. Start to finish install time was roughly 1 hour and 20 minutes with two people.
  #3 (permalink)
Old 07-16-2009, 06:22 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Thank you for sharing your experience with us. Your post was very instructive. Good luck with your refrigerator.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
HE3T Door gasket replacement gbramhall Washer Repair 1 01-14-2010 01:08 PM
GE Door Gasket Replacement TALU1944 Washer Repair 3 10-31-2009 01:28 PM
lower door gasket replacement Jerry Lovett Dishwasher Repair 0 09-23-2009 10:51 AM
Refrigerator Door Gasket Replacement Tdaniels Refrigerator & Freezer Repair 0 08-23-2009 05:33 AM
Replacement of Dishwasher door gasket vaiaar Dishwasher Repair 1 05-04-2009 05:35 PM
