Discuss
Frigidaire fridge not cooling all the time
 in
Refrigerator & Freezer Repair
Ok so my fridge is not cooling all the time. I cleaned the coils, observed the compressor fan running when
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Frigidaire fridge not cooling all the time
  #1 (permalink)
Old 01-09-2012, 02:14 AM
Junior Member
Mitimmcgraw is on a distinguished road
Default Frigidaire fridge not cooling all the time
Model Number: Plshs2692db7   Brand: Frigidaire   Age: 1 - 5 years
Ok so my fridge is not cooling all the time. I cleaned the coils, observed the compressor fan running when the compressor was running. I inspected the evaporator and fan and observed it cycle in and ok of defrost mode very good. The evaporator fan would run sometimes without the compressor on so I checked for power to compressor and got 120 when I turned the freezer control dial left or right. I changed out the defrost control board with a new adaptive control kit that came with a new wiring harness part number 5303918476. My only concern about that is the new harness had no connection for the two wires that slide into the hole just below the damper going into the freezer. What are these two wires that are wrapped in foil tape that appears to be no longer needed? Anyways this did not change my problem at all. I did notice that when I turn the freezer control dial the compressor will kick right on and run for awhile. There is plenty of room for air to circulate around the compressor and it is defrosting fine. The compressor should be running because it's above normal temps buts it's not. Any suggestions : )
Ads By Google
Related Models
General Electric PNRQ15FBL00 Wh filt sys
General Electric PNRQ20FBB00 Wh filt sys
General Electric PNRQ20FBL00 Wh filt sys
General Electric PNRQ20FCC00 Wh filt sys
General Electric PNRQ20FWW00 Wh filt sys
General Electric PNRQ21LBN00 Wh filt sys
General Electric PNRQ21LRB00 Wh filt sys
General Electric PNRV12ZBL01 Uc filtration-carbon
General Electric PNRV12ZWH01 Filtration-rev osmosis
General Electric PNRV18ZBB01 Uc filtration-carbon
General Electric PNRV18ZBL01 Uc filtration-carbon
General Electric PNRV18ZCC Filtration-rev osmosis
General Electric PNRV18ZWH01 Uc filtration-carbon
General Electric PNRV18ZWW01 Uc filtration-carbon
Admiral PNS24H9 Ref - SXS/I&W
Admiral PNS24H9A Ref - SXS/I&W
Admiral PNS24H9H Ref - SXS/I&W
General Electric PNSF31Z01 Uc filtration-carbon
General Electric PNSF35B00 Water softeners
General Electric PNSF39Z01 Uc filtration-carbon
Admiral PNT22F9 Ref - Top Mount/ I&W
Admiral PNT22F9A Ref - Top Mount/ I&W
Admiral PNT22F9C Ref - Top Mount/ I&W
Admiral PNT22F9H Ref - Top Mount/ I&W
Admiral PNT22F9L Ref - Top Mount/ I&W
Admiral PNT22F9LA Ref - Top Mount/ I&W
Maytag PNT22H9  Ref - Top Mount/ I&W
Maytag PNT22H9A  Ref - Top Mount/ I&W
Maytag PNT22H9Y  Ref - Top Mount/ I&W
General Electric PP912BM1BB Electric range
General Electric PP912KM1CC Electric range
General Electric PP912SM1SS Electric range
General Electric PP912TM1WW Electric range
General Electric PP932BM1BB Electric range
General Electric PP932KM1CC Electric range
General Electric PP932SM1SS Electric range
General Electric PP932TM1WW Electric range
General Electric PP942BM1BB Electric range
General Electric PP942SM1SS Electric range
General Electric PP942TM1WW Electric range
General Electric PP945BM1BB Electric range
General Electric PP945SM1SS Electric range
General Electric PP945WM1WW Electric range
General Electric PP950BM1BB Electric range
General Electric PP950SM1SS Electric range
General Electric PP950WM1WW Electric range
General Electric PP962BM1BB Electric range
General Electric PP962KM1CC Electric range
General Electric PP962SM1SS Electric range
General Electric PP962TM1WW Electric range
General Electric PP972BM1BB Electric range
General Electric PP972KM1CC Electric range
General Electric PP972SM1SS Electric range
General Electric PP972TM1WW Electric range
General Electric PP975BM1BB Electric range
General Electric PP975SM1SS Electric range
General Electric PP975WM1WW Electric range
General Electric PP980BM1BB Electric range
General Electric PP980SM1SS Electric range
General Electric PP980WM1WW Electric range
General Electric PR230K1 Electric range
General Electric PR437K1 Electric range
General Electric PR437M1WG Electric range
General Electric PR530BV1BB Electric range
General Electric PR530BV2BB Electric range
General Electric PR530WV1WW Electric range
General Electric PR530WV2WW Electric range
General Electric PR630K1 Electric range
Amana PRC08333A Room Air Conditioner
Amana PRC13333A Room Air Conditioner
Jenn-Air PRD3030NP Range - S/c F/s Gas
Jenn-Air PRD3630NP Range - S/c F/s Gas
Thermador PRDS304
Thermador PRDS364GD
Thermador PRDS364GL
Thermador PRDS366
Thermador PRDS484GD
Thermador PRDS484GG
Thermador PRDS484GL
Thermador PRDS486GD
Thermador PRDS486GL
Jenn-Air PRG3000P Range - S/c F/s Gas
Jenn-Air PRG3010LP Range - S/c F/s Gas
Jenn-Air PRG3010NP Range - S/c F/s Gas
Thermador PRG304US
Jenn-Air PRG3601P Range - S/c F/s Gas
Jenn-Air PRG3610LP Range - S/c F/s Gas
Jenn-Air PRG3610NP Range - S/c F/s Gas
Thermador PRG364GD
Thermador PRG364GDUS
Thermador PRG364GL
Thermador PRG364GLUS
Thermador PRG366
Thermador PRG366US
Jenn-Air PRG4802P Range - S/c F/s Gas
Jenn-Air PRG4810LP Range - S/c F/s Gas
Jenn-Air PRG4810NP Range - S/c F/s Gas
Thermador PRG484GGUS
Amana PRH08333A Room Air Conditioner
Amana PRH13333A Room Air Conditioner
Thermador PRSE304S
Thermador PRSE364GDS
Thermador PRSE364GLS
Thermador PRSE366S
Thermador PRSE484GGS
Thermador PRSE486GDS
Thermador PRSE486GLS
Thermador PRSG304
Thermador PRSG364GD
Thermador PRSG366
Frigidaire PRT134PCD0 Wwh(v3) / Top Mount Refrigerator
Frigidaire PRT134PCD1 Wwh(v3) / Top Mount Refrigerator
Frigidaire PRT134PCD2 Wwh(v1) / Top Mount Refrigerator
Frigidaire PRT134PCD3 Wwh(v1) / Top Mount Refrigerator
Frigidaire PRT134PCH0 Wwh(v2) / Top Mount Refrigerator
Frigidaire PRT134PCH1 Wwh(v2) / Top Mount Refrigerator
Frigidaire PRT134PCH2 Wwh(v2) / Top Mount Refrigerator
Frigidaire PRT134PCW0 Wwh(v1) / Top Mount Refrigerator
Frigidaire PRT134PCW1 Wwh(v1) / Top Mount Refrigerator
Frigidaire PRT134PCW2 Wwh(v3) / Top Mount Refrigerator
  #2 (permalink)
Old 01-09-2012, 05:54 AM
ApplianceJunk's Avatar
Senior Expert
APP Volunteer
ApplianceJunk is on a distinguished road
Default
and when you got 120 Vac to the compressor it runs?
__________________
ApplianceJunk.com ~ DIY Appliance Repair Forum
  #3 (permalink)
Old 01-09-2012, 11:17 AM
Junior Member
Default
Yes it starts right up
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Frigidaire freezer cold but fridge not cooling. coppergoat Refrigerator & Freezer Repair 0 08-06-2011 06:50 AM
Frigidaire Fridge and Freezer not cooling waamorais Refrigerator & Freezer Repair 1 03-03-2011 02:37 PM
Frigidaire Stops Freezing/Cooling Power Cycle Fixes for a short time. djsmith97 Refrigerator & Freezer Repair 0 11-01-2010 08:22 AM
Frigidaire Electrolux fridge not cooling properly robertson5 Refrigerator & Freezer Repair 0 09-05-2010 03:45 PM
Frigidaire fridge not cooling after an hour or so labtec Refrigerator & Freezer Repair 0 08-14-2007 01:11 PM
