Discuss
Stumped - GE Fridge Water Filter Bypass Plug
 in
Refrigerator & Freezer Repair
I have a GE Profile Performance side-by-side fridge (model TFX27PPBA), and just got RO installed for my wife (
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Stumped - GE Fridge Water Filter Bypass Plug
  #1 (permalink)
Old 01-03-2008, 07:54 AM
cockatielmax cockatielmax is offline
Junior Member
cockatielmax is on a distinguished road
Default Stumped - GE Fridge Water Filter Bypass Plug
Model Number: TFX27PPBA   Brand: GE   Age: 5 - 10 years
I have a GE Profile Performance side-by-side fridge (model TFX27PPBA), and just got RO installed for my wife (for fridge and kitchen sink, not whole-house RO). I have what I am pretty sure is the right plug to bypass the filter (both GE and a local appliance store came up with the same part number -- WR02X10173).
Removing the filter is a snap, done it many times, just a 1/4 turn and it is off. Like an oil filter on your car, but only 1/4 turn and its off. Problem is that what you then see is not going to accept the plug that I got.
I've looked for an online image of the plug -- no luck. Other than a piece of plastic on the one end to hold on to the thing, it is shaped like TV cable ... it is a hollow plastic tube slightly bigger than 1" diameter, tube wall thickness maybe 1/8", and coming out from the center of the inside of the tube is a plastic pin, about 1/8" diameter, and the the length of the pin extends slightly past the end of the tube, by about 3/8".
What I see in the bottom-center of the assembly where the filter was, is a cylindrical piece of plastic ("nipple") about 3/4" long with a small hole in the end. This nipple is designed to fit in to the opening of the filter. The plastic pin of the plug will not fit in the hole in the end of the nipple, and even if it would, that wouldn't make sense to me, because you'd be trying to get two "male" pieces to fit in to each other, and social commentary aside, that doesn't work very well.
This is why I think that some of the assembly that the filter goes on to has to be removed for the plug to be used. But I see no way to disassemble it. I am stumped.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 01-03-2008, 06:48 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
What kind of the filter did you use in the fridge?
Did you use the adapter for the later designed filters?
__________________
Professional appliance repair in Los Angeles, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
screen filter on cold water inlet hose rts3wshpel Washer Repair 2 12-01-2007 01:42 PM
water filter available? jptlkosborn Refrigerator & Freezer Repair 2 11-26-2007 07:17 PM
whirlpool water filter housing cathyjp7 Refrigerator & Freezer Repair 0 11-25-2007 01:19 PM
how to change water/icemaker filter bsmith Refrigerator & Freezer Repair 1 08-06-2007 02:02 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
