Discuss
Secondary Water Valve
 in
Refrigerator & Freezer Repair
Ordered AP4009555 a secondary water valve and the design does not match the part in place. The new part has
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Secondary Water Valve
  #1 (permalink)
Old 07-09-2009, 04:45 PM
Junior Member
Von Hefling is on a distinguished road
Default Secondary Water Valve
Model Number: ARS8265BC PARS58265BCO   Brand: Amana   Age: 5 - 10 years
Ordered AP4009555 a secondary water valve and the design does not match the part in place. The new part has a quick disconnect on the tubing and the original part is threaded.
We verified with customer service that the correct part was ordered. She suggested you might be able to help us make this part work or order the correct part.
Related Models
Amana ARS8265BS REF - SXS/I&W
Amana ARS8265BW REF - SXS/I&W
Amana ARS8267BB REF - SXS/I&W
Amana ARS8267BC REF - SXS/I&W
Amana ARS8267BS REF - SXS/I&W
Amana ARS8267BW REF - SXS/I&W
Amana ARS9107AS REF - SXS/I&W
Amana ARS9107AW REF - SXS/I&W
Amana ARS9167AB REF - SXS/I&W
Amana ARS9167AC REF - SXS/I&W
Amana ARS9167AS REF - SXS/I&W
Amana ARS9167AW REF - SXS/I&W
Amana ARS9168AB REF - SXS/I&W
Amana ARS9168AC REF - SXS/I&W
Amana ARS9168AS REF - SXS/I&W
Amana ARS9168AW REF - SXS/I&W
Amana ARS9169AS REF - SXS/I&W
Amana ARS9265BB REF - SXS/I&W
Amana ARS9265BC REF - SXS/I&W
Amana ARS9265BW REF - SXS/I&W
Amana ARS9266BS REF - SXS/I&W
Amana ARS9268BB REF - SXS/I&W
Amana ARS9268BC REF - SXS/I&W
Amana ARS9268BW REF - SXS/I&W
Amana ARS9269BS REF - SXS/I&W
Amana ARSE664BB REF - SXS/I&W
Amana ARSE664BC REF - SXS/I&W
Amana ARSE664BS REF - SXS/I&W
Amana ARSE664BW REF - SXS/I&W
Amana ARSE665BB REF - SXS/I&W
Amana ARSE665BC REF - SXS/I&W
Amana ARSE665BS REF - SXS/I&W
Amana ARSE665BW REF - SXS/I&W
Amana ARSE667BB REF - SXS/I&W
Amana ARSE667BC REF - SXS/I&W
Amana ARSE667BS REF - SXS/I&W
Amana ARSE667BW REF - SXS/I&W
Amana ARSE66MBB REF - SXS/I&W
Amana ARSE66MBC REF - SXS/I&W
Amana ARSE66MBW REF - SXS/I&W
Amana ARSE66ZBB REF - SXS/I&W
Amana ARSE66ZBC REF - SXS/I&W
Amana ARSE66ZBS REF - SXS/I&W
Amana ARSE66ZBW REF - SXS/I&W
Amana ARSE67RBB REF - SXS/I&W
Amana ARSE67RBC REF - SXS/I&W
Amana ARSE67RBS REF - SXS/I&W
Amana ARSE67RBW REF - SXS/I&W
Amana ART1805BC REF - TOP MOUNT
Amana ART1805BW REF - TOP MOUNT
Amana ART2105BB REF - TOP MOUNT
Amana ART2105BC REF - TOP MOUNT
Amana ART2105BW REF - TOP MOUNT
Amana ART2107BB REF - TOP MOUNT
Amana ART2107BC REF - TOP MOUNT
Amana ART2107BS REF - TOP MOUNT
Amana ART2107BW REF - TOP MOUNT
Amana ART2127AB REF - TOP MOUNT
Amana ART2127AC REF - TOP MOUNT
Amana ART2127AS REF - TOP MOUNT
Amana ART2127AW REF - TOP MOUNT
Amana ART2129ABR REF - TOP MOUNT
Amana ART2129ACR REF - TOP MOUNT
Amana ART2129ASR REF - TOP MOUNT
Amana ART2129AWR REF - TOP MOUNT
Amana ART2527AB REF - TOP MOUNT
Amana ART2527AC REF - TOP MOUNT
Amana ART2527AW REF - TOP MOUNT
Amana ART5400L RANGE- STD MWAVE ELE
Amana ART5400W RANGE- STD MWAVE ELE
Amana ART6000L RANGE- S/C S/I DDRAFT GAS
Amana ART6000W RANGE- S/C S/I DDRAFT GAS
Amana ART6001L RANGE- S/C S/I DDRAFT GAS
Amana ART6001W RANGE- S/C S/I DDRAFT GAS
Amana ART6002L RANGE- S/C S/I DDRAFT GAS
Amana ART6002L Range - S/c S/i Ddraft Gas
Amana ART6002W RANGE- S/C S/I DDRAFT GAS
Amana ART6002W Range - S/c S/i Ddraft Gas
Amana ART6021C RANGE- S/C S/I DDRAFT GAS
Amana ART6021L RANGE- S/C S/I DDRAFT GAS
Amana ART6021W RANGE- S/C S/I DDRAFT GAS
Amana ART6100E RANGE- S/C S/I DDRAFT GAS
  #2 (permalink)
Old 07-09-2009, 04:51 PM
Hardcore DIY'er
APP Volunteer
woodchuckie is on a distinguished road
Default
Cut the threaded end off and just insert the cut end in the new valve. You may need to hold the ring in on the new valve and release when the line is pushed in.
  #3 (permalink)
Old 07-09-2009, 04:58 PM
Junior Member
Default
Ok - Will try. Will keep you posted. Thanks for the quick reply!
  #4 (permalink)
Old 07-09-2009, 05:50 PM
Junior Member
Default
Got it in. There is no "o-ring" in the outlet on the water dispenser side of the valve. Can't stop the leak when try the water dispenser. The tubing is stiff with a coil inside so it won't give. Now what?
  #5 (permalink)
Old 07-09-2009, 06:53 PM
Senior Expert
APP Volunteer
richappy is a splendid one to behold
Default
Your tubing might be hard and the valve will not seal properly. Tubing must be soft enough to allow a compression fitting to compress properly.
__________________
  #6 (permalink)
Old 07-10-2009, 07:36 AM
Junior Member
Default
All three of the tubing pieces are the same with a metal coil inside. The other two slipped right in - the sides with the "o-ring" in the valve. Did the manufacturer of the valve leave out this "o-ring"? We don't see that we can replace this piece of tubing without taking off the back of the refrigerator.
  #7 (permalink)
Old 07-10-2009, 08:36 AM
Hardcore DIY'er
APP Volunteer
Default
Is this the one you received. It shows a compression ring on each of the three outlets. Part number: AP4009555
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Replacing secondary water valve kit jameskearns Refrigerator & Freezer Repair 2 11-03-2010 11:38 AM
Primary & Secondary Water Valves dd5087 Refrigerator & Freezer Repair 0 01-21-2010 02:39 PM
How Can I replace Water Pipe that is connected from Water Dispenser valve to Dispense Rashmikant Refrigerator & Freezer Repair 0 11-23-2009 03:04 PM
How to clean secondary filter? Hanna Dishwasher Repair 2 04-20-2009 10:11 AM
water valve secondary Dermont Refrigerator & Freezer Repair 0 03-04-2009 07:24 AM
