Freezer was frosting up due to a broken ice dispenser chute arm. I took the front panel and innards off and managed to "fix" the arm and get everything back together. However, I must have hooked something up wrong because now if you push on the ice lever, water comes out of the water dispenser and if you push on the water lever, ice comes out of the ice dispenser. Can someone tell me what I plugged in wrong or direct me to a wiring schematic that will help me out. Thank you in advance.
