Discuss
No Water
 in
Refrigerator & Freezer Repair
I have water to the frig but am not getting water to the dispenser or ice maker. Please help with
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » No Water
  #1 (permalink)
Old 07-08-2009, 08:36 AM
Junior Member
why1 is on a distinguished road
Default No Water
Model Number: KSRS25FGBL02   Brand: Kitchen Aid   Age: 5 - 10 years
Please help with ideas.
Thank you,
why1
Ads By Google
Related Models
Whirlpool KSRS25FGBL02
Whirlpool KSRS25FGBL03
Whirlpool KSRS25FGBL04
Whirlpool KSRS25FGBT00
Whirlpool KSRS25FGBT01
Whirlpool KSRS25FGBT02
Whirlpool KSRS25FGBT03
Whirlpool KSRS25FGBT04
Whirlpool KSRS25FGSS11
Whirlpool KSRS25FGSS13
Whirlpool KSRS25FGSS14
Whirlpool KSRS25FGSS15
Whirlpool KSRS25FGWH00
Whirlpool KSRS25FGWH01
Whirlpool KSRS25FGWH02
Whirlpool KSRS25FGWH03
Whirlpool KSRS25FGWH04
Whirlpool KSRS25FKBL02
Whirlpool KSRS25FKSS02
Whirlpool KSRS25FTBL00 Refrigerator
Whirlpool KSRS25FTBL01 Refrigerator
Whirlpool KSRS25FTBT00 Refrigerator
Whirlpool KSRS25FTBT01 Refrigerator
Whirlpool KSRS25FTMS00 Refrigerator
Whirlpool KSRS25FTMS01 Refrigerator
Whirlpool KSRS25FTSS00 Refrigerator
Whirlpool KSRS25FTSS01 Refrigerator
Whirlpool KSRS25FTWH00 Refrigerator
Whirlpool KSRS25FTWH01 Refrigerator
Whirlpool KSRS25IHBL00
Whirlpool KSRS25IHBL02
Whirlpool KSRS25IHBT00
Whirlpool KSRS25IHBT02
Whirlpool KSRS25IHBU00
Whirlpool KSRS25IHBU02
Whirlpool KSRS25IHSS00
Whirlpool KSRS25IHSS02
Whirlpool KSRS25IHWH00
Whirlpool KSRS25IHWH02
Whirlpool KSRS25IKBL00
Whirlpool KSRS25IKBL01
Whirlpool KSRS25IKBL03 Refrigerator
Whirlpool KSRS25IKBT00
Whirlpool KSRS25IKBT01
Whirlpool KSRS25IKBT03 Refrigerator
Whirlpool KSRS25IKBU00
Whirlpool KSRS25IKBU01
Whirlpool KSRS25IKBU03 Refrigerator
Whirlpool KSRS25IKSS00
Whirlpool KSRS25IKSS01
Whirlpool KSRS25IKSS03 Refrigerator
Whirlpool KSRS25IKWH00
Whirlpool KSRS25IKWH01
Whirlpool KSRS25IKWH03 Refrigerator
Whirlpool KSRS25ILBL00 Refrigerator
Whirlpool KSRS25ILBL01 Refrigerator
Whirlpool KSRS25ILBL02 Refrigerator
Whirlpool KSRS25ILBL03 Refrigerator
Whirlpool KSRS25ILBL13 Refrigerator
Whirlpool KSRS25ILBT00 Refrigerator
Whirlpool KSRS25ILBT01 Refrigerator
Whirlpool KSRS25ILBT02 Refrigerator
Whirlpool KSRS25ILBT03 Refrigerator
Whirlpool KSRS25ILBT13 Refrigerator
Whirlpool KSRS25ILBU00 Refrigerator
Whirlpool KSRS25ILBU01 Refrigerator
Whirlpool KSRS25ILBU02 Refrigerator
Whirlpool KSRS25ILSS00 Refrigerator
Whirlpool KSRS25ILSS01 Refrigerator
Whirlpool KSRS25ILSS02 Refrigerator
Whirlpool KSRS25ILSS03 Refrigerator
Whirlpool KSRS25ILSS13 Refrigerator
Whirlpool KSRS25ILWH00 Refrigerator
Whirlpool KSRS25ILWH01 Refrigerator
Whirlpool KSRS25ILWH02 Refrigerator
Whirlpool KSRS25ILWH03 Refrigerator
Whirlpool KSRS25ILWH13 Refrigerator
Whirlpool KSRS25KGAL00
Whirlpool KSRS25KGBL00
Whirlpool KSRS25KGBL01
Whirlpool KSRS25KGBL02
Whirlpool KSRS25KGBL03
Whirlpool KSRS25KGBT01
Whirlpool KSRS25KGBT02
Whirlpool KSRS25KGBT03
Whirlpool KSRS25KGWH00
Whirlpool KSRS25KGWH01
Whirlpool KSRS25KGWH02
Whirlpool KSRS25KGWH03
Whirlpool KSRS25PNBL00 Refrigerator
Whirlpool KSRS25PNBT00 Refrigerator
Whirlpool KSRS25PNLK00 Refrigerator
Whirlpool KSRS25PNSS00 Refrigerator
Whirlpool KSRS25PNWH00 Refrigerator
Whirlpool KSRS25QAAL00
Whirlpool KSRS25QAAL01
Whirlpool KSRS25QAAL02
Whirlpool KSRS25QAAL10
Whirlpool KSRS25QAAL11
Whirlpool KSRS25QAWH00
Whirlpool KSRS25QAWH01
Whirlpool KSRS25QAWH02
Whirlpool KSRS25QAWH10
Whirlpool KSRS25QAWH11
Whirlpool KSRS25QDAL00
Whirlpool KSRS25QDAL01
Whirlpool KSRS25QDAL03
Whirlpool KSRS25QDWH00
Whirlpool KSRS25QDWH01
Whirlpool KSRS25QDWH03
Whirlpool KSRS25QFAL00
Whirlpool KSRS25QFBL00
Whirlpool KSRS25QFWH00
Whirlpool KSRS25QGAL00
Whirlpool KSRS25QGAL01
Whirlpool KSRS25QGAL02
Whirlpool KSRS25QGAL03
Whirlpool KSRS25QGAL04
Whirlpool KSRS25QGAL05
Whirlpool KSRS25QGBL00
  #2 (permalink)
Old 07-08-2009, 10:36 AM
Hardcore DIY'er
APP Volunteer
woodchuckie is on a distinguished road
Default
disconnect the line to the water dispenser at the water inlet valve on the back where the water supply comes in and try the dispenser. if you hear the valve work but water doesn't come out, the valve is bad. If you don't hear the valve, the dispenser switch is bad.
If water did come out Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze and stop up the tube. You can take the water line off the valve and watch to see if it drips.
A strainer before the inlet valve can also get stopped up restricting flow
  #3 (permalink)
Old 07-08-2009, 01:27 PM
Junior Member
Default No Water
Woodchuckie,
Thank you for your quick response to my question. The line to the water dispenser - is this the cooper waterline feeding the valve or the water dispenser line to the left of the valve behind the cardboard like panel, it is a whitish clear tube? I can tell you now the ice and water lever on the door makes no sounds when depressed. As I look in the freezer at the water supply line which feeds the icemaker, it appears clean (not frozen).
Thank you,
why1
  #4 (permalink)
Old 07-08-2009, 01:36 PM
Hardcore DIY'er
APP Volunteer
Default
It's the plastic line. If you hear no noise from the valve it's not getting voltage. To be sure you can test if for continuity.
Test the water inlet valve for continuity using a multitester. Set the multitester to the ohms setting X100 (if available, otherwise use the nearest ohm setting). Place a probe on each terminal. The multitester should display a reading of 200 to 500 ohms. Close inspection of the inlet valve and especially the coil may reveal the exact ohm resistance rating to test for. If the water inlet valve does not pass this test, it should be replaced.
  #5 (permalink)
Old 07-09-2009, 08:53 AM
Junior Member
Default
Woodchukie, Is the valve the unit just inside the frame that has one tube on the backside and two plastic tubes coming out of the bottom? It has four electrical posts on the top, the posts run out of two round plastic parts I would assume these are the valves. On each valve one black and one green is one post that has 2 wires and one that has one wire. The 2 wire posts have electric running to them 300 and 250. The single wires have no readings. Is there supposed to be electric in the single wires? Thanks
  #6 (permalink)
Old 08-27-2009, 08:55 AM
Junior Member
Question
Hello Woodchuckie, let me start over. When I move the dispencer arm to get water or ice I get no responce. No water nor ice come through . No sound of either trying to work, nothing.Suggestions please.
  #7 (permalink)
Old 09-08-2009, 12:32 PM
Junior Member
Default No water or ice to frig
Not getting water or ice from door dispenser. When pushing the lever fpr water or ice, no product/no sound levers are working, silent not hearing anything. Ice machine is not getting water to make ice either.
Sorry I am not able to find a response to my August 27th inquiry, so I am asking again. Would like to order whatever part I need asap.
Thanks....
  #8 (permalink)
Old 09-18-2009, 01:04 PM
Frank / APP Team's Avatar
Senior Expert
Frank / APP Team is on a distinguished road
Default
Thanks....
I can give some ideas, but giving you a definitive answer as to what part is bad is going to be rather tough. The below two parts come into play, along with the wiring going to and from the components they activate. I've also provided you a link to the wiring diagram which would be needed to do a proper diagnosis.
Part number: AP3131893
Part number: AP3086666
http://www.servicematters.com/docs/w...%202200279.pdf
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #9 (permalink)
Old 09-21-2009, 05:54 AM
Junior Member
Question
Thank you Frank, not sure where either part would go. Could you please give me a call to talk about this . 18007825319. or should i just bite the bullet and have a repair service come to my home?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
water lines to hook up to the water valve on a kenmore coldspot simonf22 Refrigerator & Freezer Repair 0 12-17-2009 12:16 PM
How Can I replace Water Pipe that is connected from Water Dispenser valve to Dispense Rashmikant Refrigerator & Freezer Repair 0 11-23-2009 03:04 PM
Motor humming and water comes but blades don't spin (water pressure problem?) mtheriault3 Dishwasher Repair 4 01-11-2009 04:18 PM
made clunking sound on ice and water dispenser now iced nor water works crazyman Refrigerator & Freezer Repair 1 09-08-2008 01:12 PM
Whirlpool LA5300XM Cold water trickles, warm water flows properly ajaysheetal Washer Repair 2 02-14-2008 04:49 PM
