Discuss
Ice maker no workee
 in
Refrigerator & Freezer Repair
Ice maker not making ice, no water. The solonoid are 110 volt, correct?? no voltage at it, did no check
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Ice maker no workee
  #1 (permalink)
Old 07-08-2009, 09:10 AM
lcaley lcaley is offline
Junior Member
lcaley is on a distinguished road
Default Ice maker no workee
Model Number: KSRS251   Brand: Kitchen Aid   Age: 5 - 10 years
Ice maker not making ice, no water. The solonoid are 110 volt, correct?? no voltage at it, did no check resistance. Water line is clear. Light is blinking red on the ice maker control, sometimes it goes to solid red. I would like to use voltage at dispenser solonoid to check ice maker solonoid, are they the same voltage?? If the solonoid is good where to next??
Related Models
Whirlpool KSRS25CHBL00
Whirlpool KSRS25CHBL01
Whirlpool KSRS25CHBT00
Whirlpool KSRS25CHBT01
Whirlpool KSRS25CHSS00
Whirlpool KSRS25CHSS01
Whirlpool KSRS25CHWH00
Whirlpool KSRS25CHWH01
Whirlpool KSRS25CKBL01
Whirlpool KSRS25CKBL02
Whirlpool KSRS25CKBL03
Whirlpool KSRS25CKBT01
Whirlpool KSRS25CKBT02
Whirlpool KSRS25CKBT03
Whirlpool KSRS25CKSS01
Whirlpool KSRS25CKSS02
Whirlpool KSRS25CKSS03
Whirlpool KSRS25CKWH01
Whirlpool KSRS25CKWH02
Whirlpool KSRS25CKWH03
Whirlpool KSRS25CNBL00 Refrigerator
Whirlpool KSRS25CNBT00 Refrigerator
Whirlpool KSRS25CNLK00 Refrigerator
Whirlpool KSRS25CNSS00 Refrigerator
Whirlpool KSRS25CNWH00 Refrigerator
Whirlpool KSRS25CSBL00 Refrigerator
Whirlpool KSRS25CSBL01 Refrigerator
Whirlpool KSRS25CSBL02 Refrigerator
Whirlpool KSRS25CSBT00 Refrigerator
Whirlpool KSRS25CSBT01 Refrigerator
Whirlpool KSRS25CSBT02 Refrigerator
Whirlpool KSRS25CSMK01 Refrigerator
Whirlpool KSRS25CSMK02 Refrigerator
Whirlpool KSRS25CSMS00 Refrigerator
Whirlpool KSRS25CSMS01 Refrigerator
Whirlpool KSRS25CSMS02 Refrigerator
Whirlpool KSRS25CSSS00 Refrigerator
Whirlpool KSRS25CSSS01 Refrigerator
Whirlpool KSRS25CSSS02 Refrigerator
Whirlpool KSRS25CSWH00 Refrigerator
Whirlpool KSRS25CSWH01 Refrigerator
Whirlpool KSRS25CSWH02 Refrigerator
Whirlpool KSRS25FBAL00
Whirlpool KSRS25FBAL01
Whirlpool KSRS25FBWH00
Whirlpool KSRS25FBWH01
Whirlpool KSRS25FDAL00
Whirlpool KSRS25FDAL01
Whirlpool KSRS25FDAL02
Whirlpool KSRS25FDWH00
Whirlpool KSRS25FDWH01
Whirlpool KSRS25FDWH02
Whirlpool KSRS25FGAL00
Whirlpool KSRS25FGAL01
Whirlpool KSRS25FGBL00
Whirlpool KSRS25FGBL01
Whirlpool KSRS25FGBL02
Whirlpool KSRS25FGBL03
Whirlpool KSRS25FGBL04
Whirlpool KSRS25FGBT00
Whirlpool KSRS25FGBT01
Whirlpool KSRS25FGBT02
Whirlpool KSRS25FGBT03
Whirlpool KSRS25FGBT04
Whirlpool KSRS25FGSS11
Whirlpool KSRS25FGSS13
Whirlpool KSRS25FGSS14
Whirlpool KSRS25FGSS15
Whirlpool KSRS25FGWH00
Whirlpool KSRS25FGWH01
Whirlpool KSRS25FGWH02
Whirlpool KSRS25FGWH03
Whirlpool KSRS25FGWH04
Whirlpool KSRS25FKBL02
Whirlpool KSRS25FKSS02
Whirlpool KSRS25FTBL00 Refrigerator
Whirlpool KSRS25FTBL01 Refrigerator
Whirlpool KSRS25FTBT00 Refrigerator
Whirlpool KSRS25FTBT01 Refrigerator
Whirlpool KSRS25FTMS00 Refrigerator
Whirlpool KSRS25FTMS01 Refrigerator
Whirlpool KSRS25FTSS00 Refrigerator
Whirlpool KSRS25FTSS01 Refrigerator
Whirlpool KSRS25FTWH00 Refrigerator
Whirlpool KSRS25FTWH01 Refrigerator
Whirlpool KSRS25IHBL00
Whirlpool KSRS25IHBL02
Whirlpool KSRS25IHBT00
Whirlpool KSRS25IHBT02
Whirlpool KSRS25IHBU00
Whirlpool KSRS25IHBU02
Whirlpool KSRS25IHSS00
Whirlpool KSRS25IHSS02
Whirlpool KSRS25IHWH00
Whirlpool KSRS25IHWH02
Whirlpool KSRS25IKBL00
Whirlpool KSRS25IKBL01
Whirlpool KSRS25IKBL03 Refrigerator
Whirlpool KSRS25IKBT00
Whirlpool KSRS25IKBT01
Whirlpool KSRS25IKBT03 Refrigerator
Whirlpool KSRS25IKBU00
Whirlpool KSRS25IKBU01
Whirlpool KSRS25IKBU03 Refrigerator
Whirlpool KSRS25IKSS00
Whirlpool KSRS25IKSS01
Whirlpool KSRS25IKSS03 Refrigerator
Whirlpool KSRS25IKWH00
Whirlpool KSRS25IKWH01
Whirlpool KSRS25IKWH03 Refrigerator
Whirlpool KSRS25ILBL00 Refrigerator
Whirlpool KSRS25ILBL01 Refrigerator
Whirlpool KSRS25ILBL02 Refrigerator
Whirlpool KSRS25ILBL03 Refrigerator
Whirlpool KSRS25ILBL13 Refrigerator
Whirlpool KSRS25ILBT00 Refrigerator
Whirlpool KSRS25ILBT01 Refrigerator
Whirlpool KSRS25ILBT02 Refrigerator
Whirlpool KSRS25ILBT03 Refrigerator
Whirlpool KSRS25ILBT13 Refrigerator
  #2 (permalink)
Old 07-08-2009, 06:01 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Default
You have to have a simple multimeter to perform the ice maker troubleshooting.
The first thing I would do is swap the wires between the water dispenser and the ice maker solenoids, push the water release lever on the water dispenser and see if water will come into the ice maker. If it will then there is nothing wrong with the water valve and the water line is clear.
The next step is:
Quote:
Remove the ice maker front cover and check for 120VAC between "N" & "L" test points. Make sure the test probes are 1/2" in.
If there is 120VAC then using an insulated piece of wire (14 GA), short points "T" & "H" to run the motor. Leave the jumper in for a half of a revolution and remove it. The water valve should be energized in the last half of the revolution.
Post the results and the rest of the refrigerator model number.
__________________
  #3 (permalink)
Old 07-09-2009, 04:44 AM
Junior Member
Default Front Cover???
Hi Gene,
Please give me a point of reference, where is the "front cover". I read another post yesterday and this is where I got stopped. I never received or lost material on the refrigerator. I found this nomenclature on a tag inside the refrigerator side, Model KSRS25ILWH02 Serial SM4537790 Manufacturer Date 11/02
LarryC
  #4 (permalink)
Old 07-09-2009, 02:21 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The front cover is shown as #18 on the diagram.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL KSRS25ILWH02 | AppliancePartsPros.com
__________________
  #5 (permalink)
Old 07-09-2009, 08:20 PM
Junior Member
Default Image not available
Gene,
It looks as if I must remove the icemaker to get to front cover. It appears to be secured is a sliding tray by a single screw under the bottom, correct?
LarryC
  #6 (permalink)
Old 07-09-2009, 09:29 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
I believe so.
__________________
  #7 (permalink)
Old 07-10-2009, 07:00 PM
Junior Member
Default N&L at 20 volts AC
Hi Gene,
This freezer is designed like my Harley, not designed to be worked on!!! I finally got the "front cover" off, N&L show 20 volts. Next I tested continuity of the heater Test Points H&N and read something in the neighborhood of 8K ohms (High) not the expected 60 - 75 ohms. This appears to point to a bad heater, can you confirm my diagnosis before I purchase a new mold (heater). I am uncertain because when I remove the control module (board with the motor on it) i test the two pins coming from the bottom of the mold it shows a very low resistance. Is the high resistance coming from something in the CM or the heater itself??
LarryC
  #8 (permalink)
Old 12-21-2009, 10:15 AM
jmillar jmillar is offline
Junior Member
jmillar is on a distinguished road
Default KITCHENAID ICE MAKER model KSRS25IKBL03
The next step is:
I have done this and the motor does not turn when I jump T and H. My problem started with Ice pusher prongs frozen in ice tray mid rotation. I have good voltage across N and L and no lights in optics window. Any direction on what to do next would be appreciated.
thanks
John
  #9 (permalink)
Old 12-21-2009, 01:02 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
thanks
John
John,
Looks like the ice maker has gone bad.
- The ice maker Part number: AP3182733
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Replaced Ice Maker and noid and still no water to ice maker darrewhite Refrigerator & Freezer Repair 0 05-17-2009 07:34 AM
ice maker not working. replaced ice maker. still not working. inge Refrigerator & Freezer Repair 0 06-23-2008 10:59 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
