Discuss
Kitchenaid control board problem
 in
Refrigerator & Freezer Repair
Kitchenaid built-in side-by-side freezer working fine, refrigerator not cooling. Tech replaced evaporator motor, didn't fix problem.
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Kitchenaid control board problem
  #1 (permalink)
Old 01-02-2008, 12:39 PM
ieajrl ieajrl is offline
Junior Member
ieajrl is on a distinguished road
Default Kitchenaid control board problem
Model Number: KSSS42DAX03   Brand: Kitchen Aid   Age: More than 10 years
Kitchenaid built-in side-by-side freezer working fine, refrigerator not cooling. Tech replaced evaporator motor, didn't fix problem. I ordered and replaced the control board which is part of the diffuser assembly AP3109138. It worked fine for half a day or so and then the evaporator motor stopped running again. The evaporator motor works fine if you jumper power to it.
1. Is it possible to get a tech sheet for this model?
2. Any ideas on if the control board is the problem and why it is failing?
3. Is there any way to test the functions of this board?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 01-02-2008, 02:46 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Most likely the problem with your fridge is the thermistor (#23 on the refrigerator liner break down diagram).
- Here is the tech sheets for your fridge.
- The part number for the thermistor is AP2935875
- Here are the break down diagrams for the Kitchen Aid refrigerator Model KSSS42DAX03
Good luck.
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 01-02-2008, 03:18 PM
Junior Member
Default
Thanks for the quick reply and the tech sheet.
I measure the thermistor at room temperature at 1.47K ohms. Is this the right range for this model?
Also, the tech sheet suggests checking the door in the mechanical baffle. How would I check to see if this is functioning correctly?
Thank you.
  #4 (permalink)
Old 01-02-2008, 04:53 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Unfortunately I do not have the chart for the thermistor resistances but 1.47K ohms looks not enough. I believe it suppose to be much more.
The door in the air baffle operated by the control board (which you already replaced) according to the thermistor reading.
__________________
  #5 (permalink)
Old 01-08-2008, 04:12 PM
Junior Member
Default
You're right about the thermistor. Its resistance is too low and does not increase with temperature. I've ordered a new one. The fridge is working perfectly if I swap in fixed resistors to simulate the refrigerator at correct temperature or calling for cold air.
The air baffle in this model has three wires: common (white), open (white/brown) and close (yellow/red). The board is switching 115v ac with a triac; it always energizes one side or the other. When the baffle assembly gets power on the open side, it runs the door until it's open and then opens a microswitch. Same process to close. You can test by applying power to one side or the other.
  #6 (permalink)
Old 01-08-2008, 10:13 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Keep me updated, please.
Best regards,
__________________
  #7 (permalink)
Old 01-09-2008, 09:04 PM
Junior Member
Default
Gene,
My educational background is in EE. There is an obvious interaction going on between the thermistor, the control board and the evaporator motor. You could throw in the air damper unit too, but in my case, it's just working correctly.
I've created an approximation of the schematic for the the control board that you can see in the attached JPEG. The intention is pretty straightforward. There's an AC->DC power circuit on the right. On the left, two resisitor divider elements: one with the thermistor, the other with the refrigerator temperator setting, and a four element comparator that drives three SCRs. Two open and close the air damper. The third controls the evaporator motor.
When everything is working, the circuit does its job. In my case, the failure of the thermistor and (?) the evaporator motor caused diode D2 to short. With D2 shorted, nothing works. My refrigerator is working because I removed and tested diodes D2 and D4; since D4 was working and D2 was shorted, I have replaced D4 and not D2. In addition, I have added a series resistor between the diode bridge and the big cap. It is my opinion that not having a series resistor in a simple zener diode regulator like this is an oversight that leads to diode failure. As a side note, you should never put zeners in parallel as they did in this circuit.
With one zener and a series resistor, the board is working perfectly in my refrigerator. As you know. I don't have a working thermistor, but I'm simulating one by swapping in fixed resistors. So far, everything is working as I would expect.
Tomorrow, I'll receive the replacement thermistor and see if I'm back to a fully functional, automatic system. I'll let you know how it goes.
-- Peter
File Type: jpg Kitchenaid KSSS42DAX03 Control Board.jpg (27.7 KB, 32 views)
  #8 (permalink)
Old 01-09-2008, 09:17 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Peter,
No problem! Just let me know if you have any other questions.
__________________
  #9 (permalink)
Old 01-10-2008, 03:21 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
I also have a BSEE degree.When I worked for a hospital equipment co. we would life test designs, seems like on top of a shoddy circuit design, they never fully tested their product. Probably nobody scoped things to check for potentially damaging transients and race conditions that over stress semiconductors.
The schematic is unreadable, so have no other comments.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Speed control board den1 Washer Repair 3 12-21-2007 06:10 PM
Control Pad or Circuit Board Problem? onegumshoe Oven Repair (including Ranges and Cooktops) 2 11-20-2007 05:15 PM
Control board? rod Dishwasher Repair 1 11-05-2007 07:30 PM
Kitchenaid control board merceris Refrigerator & Freezer Repair 1 08-27-2007 10:36 AM
GE Profile Control Board ??? markham Oven Repair (including Ranges and Cooktops) 4 08-21-2007 05:15 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
