Discuss
Leaking Fridge
 in
Refrigerator & Freezer Repair
My Fridge Leaks Water Under The Unit. The Water Line Is Not Leaking What Else Could It Be? Where Can
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Leaking Fridge
  #1 (permalink)
Old 07-07-2009, 03:52 PM
JGA@REMODEL-PARTNER.COM JGA@REMODEL-PARTNER.COM is offline
Junior Member
JGA@REMODEL-PARTNER.COM is on a distinguished road
Default Leaking Fridge
Model Number: TXF27PF   Brand: GE   Age: More than 10 years
My Fridge Leaks Water Under The Unit. The Water Line Is Not Leaking What Else Could It Be? Where Can I Get A Diagram Of This Unit? jga@remodel-partner.com
Related Models
Amana TXI18J Ref - Top Mount
Amana TXI18K Ref - Top Mount
Amana TXI18M Ref - Top Mount
Amana TXI18N Ref - Top Mount
Amana TXI18R2L Ref - Top Mount
Amana TXI18R2W Ref - Top Mount
Amana TXI18VE Ref - Top Mount
Amana TXI18VL Ref - Top Mount
Amana TXI18VW Ref - Top Mount
Amana TXI20J Ref - Top Mount
Amana TXI20K Ref - Top Mount
Amana TXI20M Ref - Top Mount
Amana TXI20N Ref - Top Mount
Amana TXI21A3E Ref - Top Mount
Amana TXI21A3L Ref - Top Mount
Amana TXI21A3W Ref - Top Mount
Amana TXI21R2E Ref - Top Mount
Amana TXI21R2L Ref - Top Mount
Amana TXI21R2W Ref - Top Mount
Amana TXI21R3E Ref - Top Mount
Amana TXI21R3L Ref - Top Mount
Amana TXI21R3W Ref - Top Mount
Amana TXI21RE Ref - Top Mount
Amana TXI21RL Ref - Top Mount
Amana TXI21RW Ref - Top Mount
Amana TXI21VE Ref - Top Mount
Amana TXI21VL Ref - Top Mount
Amana TXI21VW Ref - Top Mount
Amana TXI22J Ref - Top Mount
Amana TXI22K Ref - Top Mount
Amana TXI22R2E Ref - Top Mount
Amana TXI22R2L Ref - Top Mount
Amana TXI22R2W Ref - Top Mount
Amana TXI22R3E Ref - Top Mount
Amana TXI22R3L Ref - Top Mount
Amana TXI22R3W Ref - Top Mount
Amana TXI22RE Ref - Top Mount
Amana TXI22RL Ref - Top Mount
Amana TXI22RW Ref - Top Mount
Amana TXI25R4E Ref - Top Mount
Amana TXI25R4L Ref - Top Mount
Amana TXI25R4W Ref - Top Mount
Amana TY18S4L Ref - Top Mount
Amana TY18S4W Ref - Top Mount
Amana TY18VL Ref - Top Mount
Amana TY18VW Ref - Top Mount
Amana TY21S4L Ref - Top Mount
Amana TY21S4W Ref - Top Mount
Amana TYI18S4L Ref - Top Mount
Amana TYI18S4W Ref - Top Mount
Amana TYI21S4L Ref - Top Mount
Amana TYI21S4W Ref - Top Mount
Amana TZ18Q2E Ref - Top Mount
Amana TZ18Q2G Ref - Top Mount
Amana TZ18Q2L Ref - Top Mount
Amana TZ18Q2W Ref - Top Mount
Amana TZ18QG Ref - Top Mount
Amana TZ18QL Ref - Top Mount
Amana TZ18QW Ref - Top Mount
Amana TZ18R2G Ref - Top Mount
Amana TZ18R2L Ref - Top Mount
Amana TZ18R2W Ref - Top Mount
Amana TZ18RG Ref - Top Mount
Amana TZ18RL Ref - Top Mount
Amana TZ18RW Ref - Top Mount
Amana TZ19QE Ref - Top Mount
Amana TZ19QG Ref - Top Mount
Amana TZ19QL Ref - Top Mount
Amana TZ19QW Ref - Top Mount
  #2 (permalink)
Old 07-07-2009, 04:08 PM
woodchuckie woodchuckie is offline
Hardcore DIY'er
APP Volunteer
woodchuckie is on a distinguished road
Default
Make sure the model number your gave is correct. Model Number Locator
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help. Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
  #3 (permalink)
Old 07-07-2009, 04:15 PM
Junior Member
Default Thanks
The Correct Model Number Is Txf27pfsb Ww
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Fridge leaking wolfmn33 Refrigerator & Freezer Repair 2 06-27-2009 06:24 AM
Leaking Fridge Tricatz Refrigerator & Freezer Repair 5 04-18-2009 09:39 AM
freezer.fridge not cold and leaking into fridge fruitul Refrigerator & Freezer Repair 1 09-08-2008 04:20 PM
leaking fridge mamamick Refrigerator & Freezer Repair 1 02-14-2008 01:24 PM
Leaking fridge jamie7 Refrigerator & Freezer Repair 0 08-12-2007 09:06 AM
