Discuss
Temp fluctuates drastically
 in
Refrigerator & Freezer Repair
Temps in the freezer fluctuate drastically. Ice cream very hard in the morning, come home from work and its mush!
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Temp fluctuates drastically
  #1 (permalink)
Old 01-02-2008, 11:40 AM
xvr371 xvr371 is offline
Junior Member
xvr371 is on a distinguished road
Default Temp fluctuates drastically
Model Number: 10657567790   Brand: Kenmore   Age: 5 - 10 years
Temps in the freezer fluctuate drastically. Ice cream very hard in the morning, come home from work and its mush! I changed the defrost control timer and defrost thermostat thinking that may be the problem, but this hasn't changed anything. The condensor coils are clean and have stayed clean (clean these every couple of months). I do not see abnormal frost on the coils in the freezer.
When I come home from work and find the freezer warmer than normal, I tpuch the temp control and it kicks everything on. COndensor fan, circulation fan, all come on and run until evrything is frozen again. At times when I touch or move the temp control it will kick on just for a few seconds then turns off, repeat and does it again, repeat and then it stays on?
Do I have a problem with the temp control thermostat?
Or maybe a condensor problem?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 01-03-2008, 12:12 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Most likely the problem is a bad thermostat (aka cold control).
Also I would recommend to check the start device on the side of the compressor.
Pull it out and see if it rattles. If it does, then it has to be replaced.
- The part number for the thermostat is AP3037004
- The part number for the overload and start relay assembly is
AP3119971
Good luck.
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 01-03-2008, 08:09 PM
Junior Member
Default
Thanks, I will give the thermostat a shot.
When I open the door, if I give the control panel a little love tap everything kicks on...I do not see any loose connections or shorts so maybe something is wrong in the thermostat.
Makes me feel like "The Fonz" when I give it a tap and it starts to work!
  #4 (permalink)
Old 01-03-2008, 08:16 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
No doubt the thermostat is bad.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Freezer Temp Irratic. Refer temp OK tomd Refrigerator & Freezer Repair 2 12-31-2007 04:13 PM
Temp. switch wtelwe Dryer Repair 2 12-08-2007 06:08 PM
Oven temp off shea11 Oven Repair (including Ranges and Cooktops) 0 12-03-2007 01:11 PM
oven temp too low leon Oven Repair (including Ranges and Cooktops) 2 10-05-2007 04:18 PM
Oven Temp 60F low George Whitmore Oven Repair (including Ranges and Cooktops) 0 08-13-2007 04:08 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
