| » Freezer is cold, frig is warm |
| By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use. |
Model Number: Gss25JFMBWW Brand: GE Age: 5 - 10 years
Yesterday the refrigerator was very warm. I checked the freezer and that seemed cold. I cleaned condenser thinking it was just a dust buildup. Cool air is coming into the refrigerator on the bottom left, but the top shelf is pretty warm, currently 51 degrees. The condenser motor and fan are running. Should I disconnect from power and let it sit for a while? Maybe there is an ice buildup somewhere.
The first thing I would recommend is perform the test as described in the attached service manual (page 44) and follow all instructions.
- Here are the break down diagrams for the GE refrigerator Model GSS25JFMBWW Good luck. Gene.
__________________
Professional appliance repair services in Orange County, California. |
What is the difference?
__________________
Removed the freezer back cover and saw the evaporator completely frozen solid. I performed the voltage test for the def heater, no voltage at main board connections to def heater. Performed the resistance test on the thermistor test and they seemed good. I will wait until the ice melts tomorrow and see what happens.
Check the defrost thermostat while the evaporator is frozen.
__________________
If it will come back, I would recommend to disconnect the defrost thermostat while it's still frozen and check continuity across the thermostat wires.
Replace the defrost thermostat if it's open. Gene.
__________________
| Display Modes | |
| frig warm, freezer froze up | craftkid5 | Refrigerator & Freezer Repair | 0 | 11-06-2007 10:44 AM |
| GE Refrigerator is warm freezer is cold !! | Steve705 | Refrigerator & Freezer Repair | 1 | 10-07-2007 12:24 PM |
| Fridge & Freezer Cycle Cold To Warm Back To Cold | terkel | Refrigerator & Freezer Repair | 1 | 09-25-2007 02:58 AM |
| Freezer has frost and cold/frig is not very cold | DinATL | Refrigerator & Freezer Repair | 1 | 09-14-2007 07:38 PM |
| Frig & Freezer not cold enough | BRIDGETSTEPP | Refrigerator & Freezer Repair | 0 | 08-14-2007 02:15 PM |
