gsh25sgpa ss- Lose cooling in fridge first then freezer due to iced over coils. Think problem is thermostat ($12) vs. heater/bra ($55). Would like to test thermostat but this model does not have slip connectors that I can tell (runs up into harness plug). Can I just cut the wires, check, then reconnect or replace thermostat? Any other advice on specific troubleshooting/testing?
Have you tried forcing on the heater with a jumper or through the diagnostics? Do you have the temp control buttons on the front of the freezer door
what temp should your refig and what temp should your freezer be when operating correctly. john
Ideal temperatures are below 5 in the freezer and 41 in the fridg section. To manually force defrost, remove the 3 pin power connector from the motherboard and place a jumper wire between the mating connector pins marked line and def on the motherboard. Plug in fridg, if it now defrosts, you have a bad motherboard, if not either a bad heater or defrost thermostat clipped to the top of the evaporator.
