| » My freezer coils are frozen |
Model Number: ATF1836ARW Brand: Amana Age: 5 - 10 years
My freezer coils are freezing up. Lower compartment has no cool air circulation because of this. Have defrosted and same thing happened again after about 3days. Fan is working properly. Is this a thermostat issue? If so, where is it located?
Replacement parts for AMANA ATF1836ARW REF - TOP MOUNT | AppliancePartsPros.com See the attachment for the tech sheet. First remove the evaporator cover in the freezer so you can see the coils. Do not let them de-ice. If they are heavily iced/frosted over you have a defrost problem. If yes. Manually force a defrost cycle by turning the defrost timer cam (Item 2 in Section 2) till the fans and compressor turn off. Now check the defrost heater to see if it is on. Be careful you do not want to burn your fingers. If the heater is on then the timer needs replacing, re: it is probably stalling during it's rotation so is never getting into a defrost cycle. If not on. Unplug the unit. Remove the wire for one side of the heating element (Item 13 in Section 3) from the wiring and measure it for continuity, usually around 30 ohms or so. If the heater is OK Remove one wire to the defrost thermostat (Item 18 in Section 3) and measure it, should be 0 ohms when frozen. Note that it opens just above freezing so must be frozen to check it. Also inspect it, if it is bulged at all replace it even if it measures OK. Looks like it has a built in resistor so when o[pen it will probably measure around 30,000 ohms. Your unit also has a fuse (Item 16 in Section 2). It should be 0 ohms. If both the above are OK then odds are the defrost timer contacts are toast. Best way to test this is a live test to see if you have 120 volts across the heater/defrost thermostat combo. If you do not own a meter, I would suggest you purchase a one. You can get a decent digital multimeter for under $20.00. You do not need fancy though it is nice if the leads are a couple feet long. If it saves ordering one unnecessary part it has paid for itself and you end up owning a useful tool. Most places will not let you return electrical parts so if you order it, you own it. A couple things to watch when measuring ohms and continuity 1. Always remove power from the machine otherwise you could blow your meter. 2. Always disconnect at least one side of any device you are checking. This eliminates the possibility of measuring an alternate/parallel circuit path. 3. When checking for closed contacts and continuity use the lowest scale (Usually 200 ohms). Then try higher scales. This scale is 0 to 200 ohms so if the device you are measuring is 300 ohms this scale would show an open circuit which it is not, you are just measuring outside the scale's dynamic range. There is a good STICKY at the start of this forum about it's use.
__________________
| Display Modes | |
| frostless freezer coils have frozen again | jay jay | Refrigerator & Freezer Repair | 1 | 08-11-2011 04:24 AM |
| Coils on freezer frozen 4 inches of ice above coils | Pmathas | Refrigerator & Freezer Repair | 1 | 02-22-2011 07:11 PM |
| freezer coils frozen fridge warm | davidjones | Refrigerator & Freezer Repair | 3 | 11-24-2010 07:31 PM |
| Freezer coils frozen, defrost issue | prpaul | Refrigerator & Freezer Repair | 1 | 06-10-2010 04:23 AM |
| Freezer coils frozen food thawed | campuzanos2@msn.com | Refrigerator & Freezer Repair | 3 | 06-15-2009 05:34 AM |
