Discuss
Whirlpool Side-by-Side ice maker overfills, water runs over into freezer...
 in
Refrigerator & Freezer Repair
This model has the ice dispenser in the door, but for now I just want it to make ice! I've
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Whirlpool Side-by-Side ice maker overfills, water runs over into freezer...
  #1 (permalink)
Old 07-05-2009, 03:39 PM
Junior Member
threefivezero is on a distinguished road
Default Whirlpool Side-by-Side ice maker overfills, water runs over into freezer...
Model Number: ED22DWXTN05   Brand: Whirlpool   Age: More than 10 years
I've had it for a year and the ice maker has not been connected, the previous owner did not have the ice maker hooked up either. So it has had no water in it for a very long time.
When I connect the water supply, it just continues to run into the ice cube tray, over-running and pouring water into the freezer.
It appears to have some kind of control unit that I'm assuming is supposed to allow a finite amount of water into the tray for each cycle. That's not happening, it just runs until I shut off the water supply at the source.
I'm wondering if the valve is stuck from being dry so long, and/or if I can clean or repair it... or if it's a sealed unit that has to be replaced?
This unit has the chilled water dispenser in the door as well, so the water inlet T's off from that unit, one line goes to the freezer and one to the chilled water tank. Appears to be all one unit.
Ads By Google
Related Models
Whirlpool ED22DWXTN05
Whirlpool ED22DWXTW00
Whirlpool ED22DWXTW01
Whirlpool ED22DWXTW02
Whirlpool ED22DWXTW03
Whirlpool ED22DWXTW04
Whirlpool ED22DWXTW05
Whirlpool ED22DWXWN00
Whirlpool ED22DWXWW00
Whirlpool ED22EKXPWR0
Whirlpool ED22EMXPWR0
Whirlpool ED22EMXPWR2
Whirlpool ED22F134QN0
Whirlpool ED22GWXFN00
Whirlpool ED22GWXFN01
Whirlpool ED22GWXFN02
Whirlpool ED22GWXFN03
Whirlpool ED22GWXFN04
Whirlpool ED22GWXFN05
Whirlpool ED22GWXFT04
Whirlpool ED22GWXFT05
Whirlpool ED22GWXFW00
Whirlpool ED22GWXFW01
Whirlpool ED22GWXFW02
Whirlpool ED22GWXFW03
Whirlpool ED22GWXFW04
Whirlpool ED22GWXFW05
Whirlpool ED22GWXWN10
Whirlpool ED22GWXWW00
Whirlpool ED22GWXWW10
Whirlpool ED22GWXXN00
Whirlpool ED22GWXXN01
Whirlpool ED22GWXXW00
Whirlpool ED22GWXXW01
Whirlpool ED22HDXBB00
Whirlpool ED22HDXBN00
Whirlpool ED22HDXBW00
Whirlpool ED22HPXBN00
Whirlpool ED22HPXBN01
Whirlpool ED22HPXBW00
Whirlpool ED22HPXBW01
Whirlpool ED22LFXGB00
Whirlpool ED22LFXGN00
Whirlpool ED22LFXGT00
Whirlpool ED22LFXGW00
Whirlpool ED22LFXHB00
Whirlpool ED22LFXHB01
Whirlpool ED22LFXHB02
Whirlpool ED22LFXHB03
Whirlpool ED22LFXHT00
Whirlpool ED22LFXHT01
Whirlpool ED22LFXHT02
Whirlpool ED22LFXHT03
Whirlpool ED22LFXHW00
Whirlpool ED22LFXHW01
Whirlpool ED22LFXHW02
Whirlpool ED22LFXHW03
Whirlpool ED22MK1LWR0
Whirlpool ED22MK1LWR1
Whirlpool ED22MKXLWR0
Whirlpool ED22MKXRMR2
Whirlpool ED22MKXRWR0
Whirlpool ED22MKXRWR1
Whirlpool ED22MKXRWR2
Whirlpool ED22MM1LWR0
Whirlpool ED22MM1LWR1
Whirlpool ED22MMXLWR0
Whirlpool ED22MMXLWR1
Whirlpool ED22MMXRWR0
Whirlpool ED22MMXRWR1
Whirlpool ED22MMXRWR2
Whirlpool ED22MMXRWR3
Whirlpool ED22MMXRWR4
Whirlpool ED22PBXBW00
Whirlpool ED22PBXBW01
Whirlpool ED22PCXBN00
Whirlpool ED22PCXBW00
Whirlpool ED22PEXHB00
Whirlpool ED22PEXHB01
Whirlpool ED22PEXHB02
Whirlpool ED22PEXHB03
Whirlpool ED22PEXHT00
Whirlpool ED22PEXHT01
Whirlpool ED22PEXHT02
Whirlpool ED22PEXHT03
Whirlpool ED22PEXHW00
Whirlpool ED22PEXHW01
Whirlpool ED22PEXHW02
Whirlpool ED22PEXHW03
Whirlpool ED22PFXBN00
Whirlpool ED22PFXBW00
Whirlpool ED22PKXBN00
Whirlpool ED22PKXBN10
Whirlpool ED22PKXBW00
Whirlpool ED22PKXBW10
Whirlpool ED22PKXDN00
Whirlpool ED22PKXDN01
Whirlpool ED22PKXDN03
Whirlpool ED22PKXDW00
Whirlpool ED22PKXDW01
Whirlpool ED22PKXDW03
Whirlpool ED22PKXFN00
Whirlpool ED22PKXFW00
Whirlpool ED22PMXSW00
Whirlpool ED22PMXSW10
Whirlpool ED22PMXSW11
Whirlpool ED22PQXDN00
Whirlpool ED22PQXDN01
Whirlpool ED22PQXDN02
Whirlpool ED22PQXDN04
Whirlpool ED22PQXDN05
Whirlpool ED22PQXDW00
Whirlpool ED22PQXDW01
Whirlpool ED22PQXDW02
Whirlpool ED22PQXDW04
Whirlpool ED22PQXDW05
Whirlpool ED22PQXFN00
Whirlpool ED22PQXFN01
Whirlpool ED22PQXFW00
Whirlpool ED22PQXFW01
  #2 (permalink)
Old 07-06-2009, 07:00 AM
Hardcore DIY'er
APP Volunteer
woodchuckie is on a distinguished road
Default
The water inlet valve may be staying open. You can swap the wires on the dual water inlet valve and disconnect the water line at the valve which goes to the ice maker. When you try the water dispenser the water will come out there. When you stop the water dispenser, if the water at the valve doesn't stop,try in several time it may unstick it. If it does stop after trying it several times then the problem is with the ice maker.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
side by side refrigerator - fridge side freezing food, water coming out of freezer bomb Refrigerator & Freezer Repair 8 08-30-2011 01:58 PM
Sears Kenmore side by side runs 24/7 freezer cold but not freezing patrickmcglashan Refrigerator & Freezer Repair 0 02-08-2010 12:18 PM
replase ice maker water valve on Jenn-Air side-by-side mtjim66 Refrigerator & Freezer Repair 0 12-01-2009 10:36 AM
RCA side by side refrigerator/freezer runs constanly mlocke Refrigerator & Freezer Repair 0 09-03-2009 09:00 AM
Whirlpool side by side Ice maker spews water into freezer fraserm General Talk 3 12-06-2008 08:19 AM
