Discuss
Please Help Asap<no Room For Frozen Food
 in
Refrigerator & Freezer Repair
I have an upright kenmore freezer, at first it was freezing somewhat Example Most food was defrosting, put cup of
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Please Help Asap<no Room For Frozen Food
  #1 (permalink)
Old 07-03-2009, 04:03 AM
smith81 smith81 is offline
Junior Member
smith81 is on a distinguished road
Default Please Help Asap<no Room For Frozen Food
Brand: Kenmore   Age: 1 - 5 years
I have an upright kenmore freezer, at first it was freezing somewhat Example Most food was defrosting, put cup of water in middle shelf took 6 days to freeze. Now doesn't seem to be freezing at all. There is already a splice to add coolent, I dont have a gauge, nor now the correct amount. the compresser is VERY hot, cant hear any noise to indicate it is coming on. I've been told EVERYTHING, the auto defrost is staying on to the compresser is shot. It is extremlly hot, I HAVE $300 Worth of food in chests w/ dry ice would greatly appriciate any helps, tips anything. Live in Ft Worth Texas, ill pay to fix, but not to replace parts until we remeddy the problem PLEAE HELP ASAP.
Thanks in Advance
Jeff
  #2 (permalink)
Old 07-03-2009, 07:42 AM
woodchuckie woodchuckie is offline
Hardcore DIY'er
APP Volunteer
woodchuckie is on a distinguished road
Default
Your model number would help diagnose the problem but generally-
Make sure the condenser fan near the compressor is running.
Check the evaporator coils in the freezer(the shelves on some models).
they should have a light frosting all over.
A partial pattern indicates low freon.
Too much ice will block the circulation of cold air.
Fan in the freezer should be running.
  #3 (permalink)
Old 07-10-2009, 05:06 PM
Junior Member
Default
Kenmore Upright Freezer model 253.9284215, from what I can tell, and been told this is a sealed unit so it (can't) loss coolant, like I stated previously it has already been tapped into once for sure. Where can I find a diagram of the wiring-compressor-relay?
Thanks Again!!!
The fan is on, I can hear it. I cannot see a fan any kind of coils from other forums this particular freezer is not a good choice. The sealed unit aspect puts a damper on working on the units, from what I've gathered so far I'm better of buying a new one. If I'm wrong and there is a fix to my problem please let me know. I would greatly appreciate it.
Thanks!!!!
  #4 (permalink)
Old 07-10-2009, 06:45 PM
Hardcore DIY'er
APP Volunteer
Default
Nearly all refrigerators and freezers are sealed systems. And they will loose their freon over time. Some don't .
The coils are in the bottom inside the freezer behind the back wall cover. The fan is also there but you know it's running.
You have a auto defrost system that may have failed. check the coils.
check defrost timer, defrost heater, defrost thermostat
Refrigerator Repair Guide: How To Fix a Refrigerator - ACME HOW TO.com
Your defrost system parts are shown here.http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=2539284215&productCatego ryId=0142000&brandId=0582&modelName=UPRIGHT-FREEZER&diagramPageId=00003&componentDescription=S YSTEM&documentId=P0102002&backToLink=Return%20to%2 0Sub%20Components%20list
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Freezer coils frozen food thawed campuzanos2@msn.com Refrigerator & Freezer Repair 3 06-15-2009 06:34 AM
Refrigerator freezing food, water line frozen, freezer working fine rbarber Refrigerator & Freezer Repair 0 02-01-2009 10:08 AM
frozen food elcha Refrigerator & Freezer Repair 1 01-21-2009 12:27 PM
Water in the door is frozen, and temp. goes from 32 to 41 in food area set at 37 crybaby Refrigerator & Freezer Repair 3 02-02-2008 05:44 AM
Frozen Food in the Refrigerator beatcreatorgirl Refrigerator & Freezer Repair 2 11-18-2007 10:12 AM
