Discuss
Freezer Temp Irratic. Refer temp OK
 in
Refrigerator & Freezer Repair
SYMPTOM: Discovered side-by-side freezer water on floor & food thawed. ACTION: Raised Freezer Temp setting to maximum and
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Freezer Temp Irratic. Refer temp OK
  #1 (permalink)
Old 12-31-2007, 12:36 PM
tomd tomd is offline
Junior Member
tomd is on a distinguished road
Smile Freezer Temp Irratic. Refer temp OK
Model Number: 363.50622000   Brand: Kenmore   Age: 5 - 10 years
ACTION: Raised Freezer Temp setting to maximum and freezer no longer thaws.
INVESTIGATION: Set Freezer Temp back to nominal and added a remote thermometer to obtain resulting operating temp range. At normal setting, freezer temp ranges between -15F<-->20F; Refrigerator ranges looks OK at between 36F<-->38F.
QUESTION: What might cause the large Freezer variation. I expect maybe +/- 5F variation.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-31-2007, 03:39 PM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
Suspect if you didn't adjust the cold control it would have stayed inoperative.
When it failed, what was running/not running? If not running, the defrost control was jammed, or the cold control stuck.
I would spray both the defrost timer and cold control with a non-residue spray and turn/rotate to clear any contamination.
__________________
  #3 (permalink)
Old 12-31-2007, 04:13 PM
Junior Member
Default
I'll give your suggestions a try. Hopefully I can locate the controls you mentioned. THANKS!
As for the exact symptoms when the failure occured, I was on vacation at the time and my son was the one who turned up the Freezer temp setting. Therefore I can't say if the refer was running or not running :-(
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
freezer temp has high swings - fridge ok nortonsm Refrigerator & Freezer Repair 13 06-19-2008 04:07 PM
How do I detach aluminum wire, freezer temp control? Carrie Koplinka-Loehr Refrigerator & Freezer Repair 3 12-08-2007 03:31 AM
freezer temp is ok, fridge won't cool frigidaire Refrigerator & Freezer Repair 0 10-08-2007 04:55 AM
Oven Temp 60F low George Whitmore Oven Repair (including Ranges and Cooktops) 0 08-13-2007 04:08 PM
Refer side not cooling properly, freezer okay lynbo11 Refrigerator & Freezer Repair 0 07-30-2007 08:02 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
